Yesterday, 09:34 PM | #76 |
Re: Rough idle and takeoff 250 inline
[QUOTE=HO455;9346799]One of the best troubleshooting tools for this would be a quality vacuum guage. Old school mechanics used them regularly to direct themselves towards the problem. Every Chilton and Hayes repair manual has a section on how to use one.
After reading your initial post my first thought was that you had a burnt valve. At this point if you don't want to use a vacuum guage and you want to check your compression do a leak down test instead. Properly done a leak down test will tell you if you have a valve sealing problem, a ring sealing problem, a bad head gasket or cracked block. I just ordered a leak down tester. Thanks for the links. Great info. |
Yesterday, 10:59 PM | #77 |
>>I just ordered a leak down tester.<<
Did you back that lifter away from the 2 extra turns and recheck the compression? Please do that before buying a tester. If you want to do the same thing a leak down tester will do without buying the tester. Put the piston on the cylinder to be tested, at TDC. Wrap a small rag around an air nozzle to seal it and blow air into the spark plug hole. Do remember there are two TDC for every piston. If you have a broken ring, You will hear air coming out the oil fill hole on the valve cover. If you have a bad Exhaust valve, you will hear air coming out the tail pipe. If you have a bad Intake valve, you will hear air coming out through the carb. If you have a bad head gasket, you may see air bubbles in the radiator. A leak down tester will do the same thing except give you some numbers, which won't mean a damn thing anyway. You do have a compressor for the leak down test? Sorry, just asking as I don't know. Some guys don't, but I always use some means to lock the crank from turning for a leak down test. You put 100 psi on a piston and if it wants to go down. it will. The first time it happens, you may need to change your shorts.
'67 GMC 2500, 292, 4spd, AC Last edited by RichardJ; Yesterday at 11:07 PM. |
