Old 10-13-2024, 10:52 PM   #1
kna4977
Hood closing opening issues after grille replacement
Removed old grille and installed a new one. Hood would spring open before when pressing the handle on the latching mechanism. Now I press it and it doesn’t spring up or seem to detach from the latch. If I press in on the face of the hood while holding the latch lever I can get it open, but it’s not right. Any ideas? Also difficult to get closed and latched. Don’t see anything binding or rubbing. Did loosen the fenders a bit to get the grille in easier but tightened back up.
kna4977 is offline   Reply With Quote
Old 10-14-2024, 12:16 AM   #2
Richard
Re: Hood closing opening issues after grille replacement
First thing I would do is adjust the front hood bumpers higher.
Richard
Old 10-14-2024, 01:45 AM   #3
howzzzit
howzzzit's Avatar
I think lower.
howzzzit is offline   Reply With Quote
Old 10-14-2024, 08:32 AM   #4
A1971Blazer
A1971Blazer's Avatar
you may need to adjust the hood latch bolt. It could be in a slightly different location after you loosened and retightened the fenders?
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 10-14-2024, 06:07 PM   #5
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Probably, imo.
If the hood closes like the op wants it, bumpers right, then seems to me lube, then if needed adjust the catch bolt. If that don't work move the catch plate a pinch. If that don't work your latch isn't inline.... speaking for a 71, pretty hard to screw that up. Picture of op's hood?
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
