Old 05-19-2024, 09:29 PM   #1
Ironhorse
Ironhorse's Avatar
One Piece Jack Handle - ??
I've seen references to a 1967 only (?) one piece non-folding jack handle but can not find any solid info on it after doing several attempts searching for such. Have had this handle for quite some time, thinking I got it several years ago along with a few other parts when I was looking to first restore my '71 4x4. It's like any other folding jack handle except it doesn't fold. NO markings on it at all, measures 48 1/2'' to the first curve, 8'' to the next curve and 4'' for the grip handle.
Anyone who has a '67 Chevy or GMC with a known intact and original jack set who can confirm these measurements to be consistent for a '67 only jack handle? I did learn that the jack handle being one piece mounts to the floor under the seat with some specific hardware.
Will post up some pics tomorrow as it's too dark right now to get decent pics.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 05-19-2024, 10:12 PM   #2
Getter-Done
Getter-Done's Avatar
Re: One Piece Jack Handle - ??
I am very Interested in this.
I Hope there is someone that has Knowledge of this.
84 Chevy K-20
Old 05-20-2024, 01:20 AM   #3
airkore65
i have all this in my truck. Will measure up in the morning.
1968 GMC 920 Longbed
Original 307
airkore65 is offline   Reply With Quote
Old 05-20-2024, 08:08 AM   #4
Ironhorse
Ironhorse's Avatar
That would be great, if at all possible maybe a pic or two of the jack handle and mounting brackets? The actual handle measurements would help a lot, hopefully to match the one piece handle I have. The mounting brackets may be a bit harder to get a pic of them with the seat being in the way. I noticed in your signature that you have a '68 GMC 920. That being a Canadian truck, is it a 3/4 ton?
Wellington, Ks
Old 05-20-2024, 08:54 PM   #5
airkore65
Yes , 1968 920 is a 3/4 ton
Original 307
Old 05-20-2024, 09:14 PM   #6
Ironhorse
Ironhorse's Avatar
Totally different than what I have in mind for the jack handle for a '67. Is that jack original to the truck from new? Maybe a Canadian supplied truck jack (?) but the hydraulic bottle jack would be in-correct from my understanding for all 67-72 GM trucks here in the US. The standard jack supplied would be a screw type jack using a long handle to operate the screw fitting of the jack. Adding a pic of a complete jack set showing what I am referring to, altho for '67 the jack handle does NOT fold as in the pic. Pic shows a 1/2 ton and 3/4 ton lug wrench, only one would be supplied with the truck when new. A one piece jack handle with a 48 1/2'' straight run, a 90 degree bend for an 8'' run and then another 90 degree bend for a 4'' length. Will post a pic tomorrow of the one piece handle and the folding handle I have together which might explain better. "One pic is worth a thousand words" kind of thing.
Wellington, Ks
Old 05-20-2024, 11:02 PM   #7
chewychevy67
I'm just curious how it would mount to the floor in a 67 under the seat being that long. I thought thats why it had a fold in it. Pictures will help
chewychevy67 is offline   Reply With Quote
Old 05-21-2024, 08:20 AM   #8
Ironhorse
Ironhorse's Avatar
Took a couple pics of the straight one piece handle and the folding handle. Nearly identical with only a slight difference to the folding handle having a more gentle bend.
As to the straight jack handle fitting under the seat, both the '67 truck bench seats and some "early '68 ? " truck bench seats folded forward away from the gas tank. That would make storing the straight jack handle back in position much easier. That's some of the info I'm trying to find out from any board member who has an original '67 truck with the known history of it for originality. Inquiring minds want to know, LOL.
Wellington, Ks
Old 05-22-2024, 10:12 PM   #9
Ironhorse
Ironhorse's Avatar
Surely some one has some good, solid and true info about the '67 one piece jack handle I've seen reference to. Looking for that member who has a known original unmolested example with everything intact. A true time capsule for learning and knowledge. My '71 4x4 was so rough, rode hard, put away wet and ragged on but......it being a long bed 4x4 to me it was a diamond in the rough. Need an exact opposite for '67 that is as delivered with no major changes made from factory.
Wellington, Ks
Old 10-15-2024, 10:24 AM   #10
gmc 2500 4x4
I was wondering if specific trucks had different jacks, I have a short one and a taller one, same folding handle. I also came across different jack labels
gmc 2500 4x4 is offline   Reply With Quote
Old 10-15-2024, 12:09 PM   #11
MJN
MJN's Avatar
Yes, I posted a shot from one of my parts catalogs in this post that shows the different jacks depending on application, https://67-72chevytrucks.com/vboard/...highlight=jack
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 10-15-2024, 12:17 PM   #12
gmc 2500 4x4
Thanx, I just found some info in my books too, assembly manual helped. Now I need to find a tire iron that goes with the wrench 3730756
Old 10-15-2024, 01:22 PM   #13
68 C10 Driver
I have a 68 C10 that has the one-piece, non-folding jack handle and yes, my bench seat also folds forward. I have removed my 'in-cab' fuel tank and have a mounting wall that things like my first-aid kit, inverter, additional fuse block, and jack handle will mount to.
68 C10 Driver is offline   Reply With Quote
Old 10-15-2024, 03:02 PM   #14
gmc 2500 4x4
Info
Old 10-15-2024, 03:04 PM   #15
gmc 2500 4x4
Anyone recognize this jack on the left? Opens up like 16" the same as the one on the right.
