Old 10-15-2024, 01:22 AM   #51
leegreen
Re: stereo install in AD cab, my ideas
and final result
leegreen is offline   Reply With Quote
Old 10-15-2024, 02:26 PM   #52
Klorne
Awesome, thanks for all the pictures and write up. I have an old delete plate and piece of dash, so I'm going to play with it and see if I can make something work. I'm thinking that finding the right pivot point might be the key.
Klorne is offline   Reply With Quote
Old 10-15-2024, 02:46 PM   #53
leegreen
yes, the pivot is the key so the door rotates around the edge of the head unit and is flush when closed. I only showed the final stage of CAD model, there were a few iterations thumbtacked to a mock up drawing until the pivot was right.
I should mention that my head unit is mounted on top of a flat platform I built behind the dash. Held down with zip ties. It only weighs about as much as a pack of cards. This leaves the sides open so my hinges work. If you need to side mount your head unit the inner hinge will need to be a skinny C shaped thing like the ashtray picture.
Old 10-15-2024, 02:51 PM   #54
dsraven
Some more modern cars use a little shock absorber to help with slow open and close of glove box doors. Maybe you can use something like that. Plastic non gas charged thingies
Old 10-15-2024, 02:53 PM   #55
leegreen
....I'd planned a little knob to pull the door open, but it wasn't needed. if you push near the top edge with first finger it will open enough to flip up the bottom edge with your thumb
Old 10-15-2024, 03:02 PM   #56
leegreen
if you were doing something larger you might need that. This works quite nicely with a smooth action with just metal on metal. I could see this wearing out eventually and getting loose but it has several months use now over 2 summers with no issue. Plan A if it gets loose is to bend the inner hinge a tad for more interference.
Old 10-15-2024, 03:38 PM   #57
Klorne
My plan is to put a little cubby in the stereo hole and have the flip up door on it. Not going to have a stereo. Well, not a head unit anyways. Going with a Bluetooth amp under the seat, so nothing in the dash.
Old 10-15-2024, 03:53 PM   #58
leegreen
wow, looks like you should be able to cnc some goodness to fit!
Old 10-15-2024, 04:05 PM   #59
Klorne
If I only had a cnc machine, lol. By the way, that's not my dash. From a company called lsfab, they make a bunch of knick knacks for these old trucks.
Old 10-17-2024, 07:20 PM   #60
Klorne
Leegreen, I really like your overhead gauge pod. I've been looking online for ideas to do something like that, but all the ones I've seen look like they've taken an overhead console out of a modern truck and bolted it to the roof of their old truck. Just looks out of place. Yours looks like it belongs there. I would love to see the finished product. I'm sure there was a lot of measuring, cutting, bending, re-measuring, re-cutting, re-bending... lol.
Old 10-18-2024, 01:14 AM   #61
leegreen
'finished' ? we don't use that word around here.
Here is the current state of 'good enough' that got me through the last couple summers.
I need to do a headliner, door panels, rear cab panel to start to think of the interior as finished
Old 10-18-2024, 12:31 PM   #62
Klorne
How do you find the gauge placement? Are they easy to glance up at? I'm putting a turbo in my truck, so I'll have a few extra gauges like oil pressure, wideband and boost. And an extra couple of lights would be nice too.
Old 10-18-2024, 12:52 PM   #63
leegreen
The gauges are easy to see, just above the mirror. Ideally you'd angle them all towards the driver so the faces were perpendicular to the line of sight, but that makes the metal working a lot more - interesting. And this has worked just fine, I don't feel compelled to change it.
I have not run any interior sunvisor, I have one on outside of cab. Interior visor might not look good with this console? I have not held one up to consider it so far.
There is not a ton of room up there, 4 gauges probably would have started to run out of room between the console and truck Sheetmetal for the gauges. You could make it deeper but that would start to make the cab seem smaller and bring the gauges too close perhaps.
The cable capacity of the A pillar is limited as well, i think I have 6 or 7 14-16g wires in one of them and it was starting to get tight pulling the last up.
The little LED lights turn on independently, each has a switch. They give about enough light to see the dash, and maybe spot something you dropped. The OEM cab light with 12V bulb is very bright, easily read a book / map.
Old 10-23-2024, 01:16 AM   #64
mr48chev
mr48chev's Avatar
No loss not running an interior visor. Unless you are driving directly into the sun or are driving west for hours on end with the sun hitting you from the side you never have much need for them anyhow.
My ongoing truck projects:
Old 08-22-2025, 03:16 PM   #65
leegreen
Since I recently installed a headliner, I might upgrade the status to finished-as-good-as-it-gets for now:
Name:  Screenshot 2025-08-22 115643.jpg
And here is a view of gauges, pretty much from my driving POV. Angling the gauge faces towards driver would be nice, but this is workable.
Name:  Screenshot 2025-08-22 115517.jpg
I may replace the tacky thermometer filling the right hand gauge spot with
a three in one Water / Oil / Volt gauge as the gauges I built into my cluster seem to be lacking in accuracy.
Old 08-23-2025, 01:24 PM   #66
mr48chev
mr48chev's Avatar
That is trick and you could make it so you used the original fasteners that hold th delete plate (or self made duplicate) in and even use the delete plate as the flip up door with no welding on the dash.
Old 08-23-2025, 01:40 PM   #67
mr48chev
mr48chev's Avatar
One could do their own take on an under dash gauge panel for a radio mount.
One could even add an AC vent on each side or a gauge or power plug on the side.
Back in the CB radio days there were several decent looking CB radio mounts around similar to the is one that is designed for boats. A lot cleaner than just a bracket to mount the radio in.
For overhead one might snoop the conversion/upgrade vans in the wrecking yards as a lot had an ovehead consol in them that might be adapted.
