Yesterday, 01:58 PM | #1 |
Quadrajet question
Have a quadrajet on a 72. The front vacuum port is plugged which I understand to be normal. It has one on the passenger side near the choke setup that is open and not capped. What is this supposed to go to or should it be capped? Here’s a pic.
Yesterday, 02:16 PM | #2 |
Re: Quadrajet question
It's called a diverter port. I have no idea what it would be used for, but I think it has vacuum at idle. Mine is capped.
Yesterday, 02:20 PM | #3 |
Charcoal canister full time manifold vacuum port.
Yesterday, 02:29 PM | #4 |
The one on the side of the carb is a manifold vacuum source for the air cleaner Thermac snorkel valve.
If you are looking for the utmost correct look, the TCS emission control system is missing, and it appears the lines to the charcoal canister are gone.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
Yesterday, 04:22 PM | #5 |
My quadrajet has a canister purge port on the front. It is ported vacuum. Anytime engine is off idle it activates the switch at the canister which in turns allows the canister pcv port to open and dump the fumes into the pcv port at the carb through a tee. I changed my old canister and added an external switch. New ones don't have it built in and it works great. No more gas fumes.
Yesterday, 06:46 PM | #6 | |
What did it all look like originally and where did the charcoal canister mount? Did all the 72s come with them? For now I'm going to cap it off. |
Today, 01:32 AM | #7 | |
