Old Yesterday, 01:58 PM   #1
kna4977
Quadrajet question
Have a quadrajet on a 72. The front vacuum port is plugged which I understand to be normal. It has one on the passenger side near the choke setup that is open and not capped. What is this supposed to go to or should it be capped? Here’s a pic.
kna4977 is online now   Reply With Quote
Old Yesterday, 02:16 PM   #2
howzzzit
howzzzit's Avatar
Re: Quadrajet question
It's called a diverter port. I have no idea what it would be used for, but I think it has vacuum at idle. Mine is capped.
howzzzit is offline   Reply With Quote
Old Yesterday, 02:20 PM   #3
geezer#99
geezer#99's Avatar
Charcoal canister full time manifold vacuum port.
geezer#99 is online now   Reply With Quote
Old Yesterday, 02:29 PM   #4
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Quadrajet question
The one on the side of the carb is a manifold vacuum source for the air cleaner Thermac snorkel valve.
If you are looking for the utmost correct look, the TCS emission control system is missing, and it appears the lines to the charcoal canister are gone.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old Yesterday, 04:22 PM   #5
howzzzit
howzzzit's Avatar
My quadrajet has a canister purge port on the front. It is ported vacuum. Anytime engine is off idle it activates the switch at the canister which in turns allows the canister pcv port to open and dump the fumes into the pcv port at the carb through a tee. I changed my old canister and added an external switch. New ones don't have it built in and it works great. No more gas fumes.
Old Yesterday, 06:46 PM   #6
kna4977
Not sure why anyone would want a TCS system and I understand why people would remove them and throw them away. They seem like a PITA. Bet a complete working system is super hard to find today.
What did it all look like originally and where did the charcoal canister mount? Did all the 72s come with them?
For now I'm going to cap it off.
Old Today, 01:32 AM   #7
howzzzit
howzzzit's Avatar
Canister next to and below the battery. They were an answer to non-vented fuel tanks. The charcoal absorbed the fuel vapors instead of venting out the cap. My 72 is a C10 and I may be wrong, but I believe only 1/2 tons had the canister and smog setup that year. Someone will know for sure.
Old Today, 07:20 AM   #8
1970cstblazer
Exclamation Re: Quadrajet question
You do realize that you can have the solenoid present, and all hooked up, and vacuum can pass through it as long as it is not electrically energized...
Old Today, 09:39 AM   #9
1970cstblazer
Old Today, 12:29 PM   #10
geezer#99
geezer#99's Avatar
Actually you get no vacuum thru it until you’re in high gear.
Old Today, 01:01 PM   #11
1970cstblazer
I'm not talking about an actual original functional system. I am referring to a "for appearances only" system. Verified with a hand vacuum pump/gauge, the solenoid on my 1970 allows vacuum through it when the system has had it's power source rendered inoperable. It looks 100 percent correct and allows full vacuum to the distributor advance can at all times when there is manifold vacuum available.
