10-21-2024, 09:19 AM | #176 |
Re: 1970 K20 Z62 Full Restoration
On my '70, I used an original used driver's side front fender inner skirt, and a new passengers side. The drivers side had schutz coating on it from the factory, so I applied 3m schutz with a special air schutz gun on the passengers side to match. I also applied this coating on the rocker boxes to replace what stones had worn away.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
10-21-2024, 12:16 PM | #177 | |
I'm trying....
Thanks for the link. Eric has tried/used all measure of liners/coatings/stone chips...just on our trucks. It's always a challenge to match the factory textures whether it's a Blazer top or a fender well. The main concern for me on this one is whether I'll have enough guts to let him go full factory and sloppily spray underneath this truck as was originally done and cover up a lot of nice finishes and details....we'll see.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
10-21-2024, 12:20 PM | #178 |
I'm trying....
Keith got back to me and he didn't disappoint. Here's his response on the question of the bed floor:
The bed floor was received assembled from the supplier (Checker Motors, or GM Met Fab Indy or whatever). Meaning: the main floor panel itself, plus the cross sills and misc brackets and such. The bed sides and front panel were then added to the floor in the cab (body) shop, which is the same area where the cab was welded together from all the little bits and pieces you start with. The cab and box together then make their way through the rest of the cab shop and on to paint and then trim. In terms of primer color - it varies a bit based on model year and final assembly location. I would say you are doing the right thing in duplicating whatever you found underneath the paint. I don't have any '70 Fremont photos handy but these are from Flint circa 1979. https://www.73-87.com/7387info/Assembly%20Line.htm (Photos 5,6,7 and 8 are Line 2 Blazer/Suburban. Photos 9, 10 and 11 are pickup cab shop and paint)
10-21-2024, 12:30 PM | #179 |
I'd have a hard time coving up the detail. I too am not sure what im going to do on the underside of the cab. I guess ill wait to see what yours looks like first.
10-22-2024, 07:40 AM | #180 |
image by [url=https://www.flickr.com/photos/97391199@N06
I was degreasing my high hump trans cover the other day and found an unusual color I’d say it’s like a flat UPS truck color, first time I’ve run into this Great build so far
Tags |
1970, 4x4, factory, k20, restoration |
