Old 10-14-2024, 07:47 PM   #1
4u2nv
alignment
Anyone lowered their 1989 gmc 3500 dually and have any specs on it ???
Had mine done and they went by original height specs , something in the handling doesn't seem right , feels like it's skating a bit .
I didn't lower it so I don't know how much
Here's a picture maybe you can tell by it
4u2nv is offline   Reply With Quote
Old 10-16-2024, 06:53 AM   #2
Re: alignment
Check with member LUV2XCLR8. Off top my head he would probably have the info.
Old 10-21-2024, 12:39 PM   #3
SCOTI
SCOTI's Avatar
Re: alignment
In case others might be searching for some info....
https://67-72chevytrucks.com/vboard/...41&postcount=5
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-23-2024, 06:28 AM   #4
4u2nv
Re: alignment
Took it back for another look at things did a couple things on it and still is the same , we figure it's the steering box , with 355000 on it it very well could be worn out , I will try a new one
Thanks for your replies
Old 11-05-2024, 05:30 AM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: alignment
When you say specs, are you talking about alignment or the parts used?
My 1988 lowered 6/9, and drives awesome considering the drop.
(We did set the camber at -1 to keep tires from rubbing fender)
Stupid assumption, do the wheels have the metal plates
between the rim and the lugs to help center the nuts?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-05-2024, 07:27 AM   #6
4u2nv
Re: alignment
Specs for alignment and yes it does have those plates
What did you use for the front drop
Old 11-26-2024, 07:31 PM   #7
4u2nv
Re: alignment
What did you do to get that 6 inch drop in the front and who's product ??
