#101 |
Re: 1970 C10 ChassisFab Build Thread
Nice job on the tubs. Did you have to get extra tubs for your filler piece? When I did mine I used scrap that I cut out of my inner bed sides when I raised the floor. I still need to finish welding my tubs, it's been over a year!
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 | Oscar the 70 C10 - C10 Concept/Development Photos: Master Thread |
#102 |
That's super clever I hadn't even considered that! I did buy two tubs for each side... I wish they still made CHUB TUBz in the stock wheel width
My 1970 C10 ChassisFab LWB to SWB Build Thread |
#103 |
Fitting some pieces for the raised fiberglass inner fenders
#104 |
![]() Join Date: Aug 2004
Nice clamp usage! Those pieces aren’t going anywhere
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#105 |
New tailgate fits alright! Working on the bed floor, rear tubs, and tailgate filler panel.
#106 |
![]() Join Date: Oct 2012
Where did you get the tailgate from?
Scott 1970 C10 Restomod|454/700R4|LWB-->SWB Build Thread 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
#107 |
LMC for nearly all of my parts
#108 |
How did it line up with the bed sides? I need a tailgate, not sure if I want to go the LMC cheaper route or pony up and buy an OG old metal tailgate.
#109 |
PROJECT 7DEUCE
Shes coming along...
GO BIG GREEN GO DUCKSMEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#110 |
I can't complain with this one from LMC. I used the stock hinges and handle with it to make it feel more "solid" like the original
#111 |
Trying something different with the tailgate filler panel. This is an inner tailgate skin. It's gonna take a fair amount of fit and finish back here, along with installing the emergency shrader valves and remote battery posts.
#112 |
Is that panel left over from the original tailgate? If so great re-use of material.
#113 |
![]() Join Date: Mar 2011
WOW factor..... great Idea !
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#114 | |
I might trim off the dented part near the bottom or tack some new sheet metal right there.
#115 |
Inching along
#116 |
First thing I thought in that picture on a Friday night is.... what's in that cooler in the back lol. But that is a Purdy Orange small block!
#117 | |
#118 |
chevy truck fan
I would swear that is a model engine & not a 1:1 real engine!! very nice detail... and overall build....
#119 |
![]() Join Date: Jan 2007
Project "C10 Fever" (68 factory black 396 swb) Project “Faded Glory” (71 c10 med bronze original paint refresh) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
#120 |
AC Condenser going in
#121 |
Got the rear tubs in place. I need to trim a little from the inside since they are rubbing the outer bedside skin. After this, I noticed the bedside rails at the top of the sides are bowed out on both sides.
Has anyone had to straighten this area? I'm thinking a long 2x4 and big hammer whacking towards the top of the rail will straighten it a bit.
#122 |
That bed turned out great. Not sure about a 2x4 and big hammer, but maybe a piece of angle iron and some clamps to help bend it back in. Is it like that on both rails?
#123 | |
It was a farm truck so the PO must have had some heavy stuff rolling around in the bed lol.
#124 |
can you tell me who's AC kit your using my cab is a non AC cab Im going to convert ..I converted and used Vintage in my Cheyenne( was a factory AC cab) years ago but their kits are Gens ahead now from when I installed mine ....looking at the condenser install looks clean
#125 |
![]() Join Date: Jun 2002
Nice work on this truck! What did you use to paint the engine? Did you use a clearcoat?
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
| Bookmarks |
