#26 |
![]() Join Date: Aug 2004
Re: 67-72 Rear Bumper On Fleetside
Post #13
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#27 |
Don't suppose anyone has tried this on a Suburban? Looks like the cut out for the license plate would be a good place for a trailer hitch receiver. Are the truck bed corners much different than the Suburbans?
#28 |
#29 |
#30 |
The crappy 62 "bar stock" that came with stock bumper. So I basically had flat bar and welded 90* and drilled holes. A 45* can be added, like stock. I used 1/4" shimming out and tailgate clearance. Used some aluminum "pan" stock to make plate holder
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 Last edited by LVPhotos; 10-22-2024 at 05:06 PM. |
#31 |
If you look at the stock bumper shadows you can see the "kit" installed. I just used what was there and rearrange the parts and welded
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#32 |
![]() Join Date: Mar 2011
Here's my painted version.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
| Bookmarks |
