Old 10-24-2024, 07:11 PM   #5076
72c20customcamper
72c20customcamper's Avatar
Re: What did you do to your truck today.The 3rd chapter
Close up
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-24-2024, 07:13 PM   #5077
72c20customcamper
Originally Posted by 3757chevy View Post
Very cool. Congrats.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-27-2024, 08:32 AM   #5078
zicc1835
zicc1835's Avatar
played with the throttle cable and kick down/detent bracket I like the way it turned out all aftermarket stuff except the accelerator cable so much easier with no fenders to lean over.....with my abused and old back
zicc1835 is offline   Reply With Quote
Old 10-27-2024, 08:38 AM   #5079
zicc1835
zicc1835's Avatar
New headlamps and front side markers . The side markers are Woodall’s guess they are discontinued paid 10 bucks for the pair . The headlamps are United Pacific brand . Much brighter than the Sylvania halogens that were in it
I like..... looking good
Old 10-28-2024, 09:31 AM   #5080
NathanJ72
New Member
Finally finished rebuilding this with a kit from Cliff's High Performance. Waiting on a replacement spring for one of the air/fuel mixture screws. One of the springs disappeared. Hopefully it will be okay. Thought about getting another carb like this, a 7042210. My 1970 Chevy C10 Custom has a 350 as it always has, but this 350 came out of a 1973 Bel Air and the Quadrajet is a 1972 model with divorced choke. Still unsure if I should convert to HEI or not. She has a brand new American Autowire Harness in with more to install.
NathanJ72 is offline   Reply With Quote
Old 10-29-2024, 05:18 PM   #5081
'68OrangeSunshine
'68OrangeSunshine's Avatar
I have converted to HEI on 3 trucks and never regretted it.
Does the American Autowire harness have an HEI feed line?
If not you can get an HEI pigtail [Packard type dual connector 12 V to Coil/ Tach] from Jegs. Run a 12 ga wire from IGN Unfused on the fuse block to the Coil hot line. Disconnect the 20 ga Yellow lead to the points coil. Tape it off or delete it. it's connected to the Orange/Purple/White Resistor wire from the Bulkhead Connector. This line drops voltage to the Coil when heated. Less than full 12 VDC to HEI Coil will burn the Module up.
Many other posts about HEI conversion on this site, if mine was confusing.
Old 10-29-2024, 08:06 PM   #5082
72c20customcamper
Started the disc brake conversion on the 68 . Was a little worried the lower control arm would hit the wheel but it’s got plenty of clearance. Some before and after .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-29-2024, 08:09 PM   #5083
72c20customcamper
Changing all the ball joints the uppers were definitely original lowers not sure about . They wernt worn but the dust boots were shot .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-29-2024, 10:09 PM   #5084
PanhandleShantyman
I have been digging into the front end on my relatively new to me '69 1500 for the first time and there is a dust boot on a lower ball joint that is pretty shredded on one side. I was squinting at it and wondering if I could slap a little Flex Seal on it and forget about it for a couple years. How big of a job is is to change the ball joints??
PanhandleShantyman is offline   Reply With Quote
Old 10-30-2024, 08:35 AM   #5085
72c20customcamper
Not a hard job with the right tools . The lowers pop out with a hand press I bought this one recently as my old one bent really bad doing my 3500 Dodge . The uppers if original I grind the rivet heads and drill them out a bit . If I had an air compressor I would use the air chisel . I’m doing this job at my rental property .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-30-2024, 12:05 PM   #5086
NathanJ72
New Member
Yes the kit came with provisions for both, minus the resistor. If I do I will hang on to the old one just in case. Thanks for the reply!
Old 10-30-2024, 04:22 PM   #5087
'68OrangeSunshine
I did the same on my '68 C/10 Stepside w/ 292 L6. I converted to Pertronix, using a points type Delco Remy L6 Distributor. But I did not rip out the points wiring. After about 7 years the Pertronix burned out. I went back to points operation for a year, until I had amassed all the right stuff for the rarer L6 HEI.
Old 10-30-2024, 04:40 PM   #5088
NathanJ72
New Member
what points do you trust to put in these distributors? I'm leary of a lot of new stuff. But then you have the same with the unit that goes into the HEI distributor. I do IT and I LOVE mechanical over electronics lol.
Old 10-30-2024, 05:08 PM   #5089
'68OrangeSunshine
Well, I haven't used points on either of my running trucks* in about 8 years.
[* '68 C/10 -- 292 L6; '71 GMC JIMMY K/1500 -- 350 V8]
I had a bunch of legacy L6 points and condensers. I liked Standard Blue Streak when I could get USA-made ones. The ''Asianization'' of replacement parts was one more reason to move to HEI.
There is more than one ''unit'' inside the HEI distributor.
- Module [Keep a spare in your glovebox, w/ the white insulator grease]
- Pick Up Collar and Harness
- Coil, Ignition
- Contactor ''Button'' from inside Coil to exterior cap Terminal Stud
I understand your preference for uncomplicated mechanisms over Electronic systems. I have a Feuerhand kerosene lamp on my back deck to illuminate my BBQ.
But GM HEI really is a performance upgrade.
Old 10-30-2024, 10:11 PM   #5090
zicc1835
zicc1835's Avatar
tonight I layed out the cross sills and the bed strips so I could determine where the fuel fill will line up .....I want to put a round stainless fuel access hatch over the fuel cap IS 2.5 ROUND so I need like 4 inch access hole
ANY SUGGESTIONS ?
I bought this Boyd welding fuel tank years ago used... never had fuel in it couldn't pass up the deal so I will make it work
Old 10-31-2024, 12:45 AM   #5091
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Did u buy the side markers used or find a vendor with them.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 10-31-2024, 08:16 AM   #5092
72c20customcamper
They were brand new from a vendor at the C10 fall festival. Dave’s truck parts
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-31-2024, 09:48 AM   #5093
NathanJ72
New Member
- Coil, Ignition
Now I guess I have to find one. What is a reasonable price for a functional one? What brand to get for replacement parts?
Old 10-31-2024, 11:03 AM   #5094
Scooter Davenport
I diagnosed a fuel gauge problem (bad sending unit), reattached driver side vent window latch, un-seized and reinstalled the sun visors.
Scooter Davenport is offline   Reply With Quote
Old 10-31-2024, 12:47 PM   #5095
1970cstblazer
1970cstblazer's Avatar
Thumbs up Re: What did you do to your truck today.The 3rd chapter
I was having an issue with the factory AM/FM radio in my Blazer. The volume would fade in and out, and sometimes would not come back at all unless you shut off the radio and turn it back on. The weakest link on these old Delco radios is the germanium output transistor. I noticed that a previous owner had replaced the output transistor with a cheap replacement, not a Delco part. I happened to have an old convector (amplifier) assembly from an early '70's Pontiac that had two original DS-501 Delco output transistors. I swapped one onto my radio, which on the truck/van AM/FM units is easily accessed in the aluminum heat sink on the side of the radio facing the passengers side of the truck. After swapping it out, I bench tested the unit, and it came to life, and the irregular volume was gone.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 10-31-2024, 08:01 PM   #5096
72c20customcamper
Coming along . And yes I cleaned the work area afterwards
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-31-2024, 08:37 PM   #5097
zicc1835
zicc1835's Avatar
looking good.... Im sure you will be happy with the performance of this conversion
Old 10-31-2024, 09:02 PM   #5098
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yup, the difference in braking performance is worth it. Many will argue differently, but I'm on board with the pads wiping the rotors in the rain and making better stops due to less wet brakes. I'll have to say that drag racers may see an advantage in stock classes due to lower front brake friction with drum brakes, off the line...they tell me.
~Steven
Simi Valley, CA
Old 11-01-2024, 12:47 AM   #5099
'68OrangeSunshine
Shop: RockAuto, Jegs, Summit Racing.
I don't know what you'd find at your local junkyard.
When you look, add ten years later to your parts search, as there were no HEIs in 1968 [for example] so pretend you have a '78. Computers have a hissy fit if you try to get a more modern part for an older truck.
But you want the first generation of GM HEIs. Later ones have computer interfaces.
I hesitate to recommend AC Delco/Delco Remy anymore. They're now made offshore just like other Asian crap. Not worth paying more for the name with Americans unemployed.
Basic distributors seem to run about $75 at Jeg's.
I once bought a new [US-made] MSD Distributor Cap, and the contacts inside were too big. The rotor broke up hitting them. I don't buy MSD anymore.
I just looked up a '78 HEI at RockAuto. $186 for a reman Delco Remy. That's including core charge and NO Coil included. Forget them.
Tucson Craigslist shows one for $125. They say it's for an '85 Corvette! No thanks.
Summit seems very proud of theirs. Prices range from $97 to over $300.
Or look on the Parts Bord on this site.
Good hunting.
Old 11-05-2024, 12:34 AM   #5100
crazyjeenyus
crazyjeenyus's Avatar
Installed the Blazer style fuel tank in the '65. My box is in really rough shape, and the wood is rotten in spots, so I opted to perform the installation while leaving the box on. I couldn't find any online resources for this, so I documented the installation and posted it on youtube.
Here's the link if anyone cares to watch:
https://www.youtube.com/watch?v=MQ_JNM3lkpA
Cheers!
'67 c10
'65 c10
crazyjeenyus is offline   Reply With Quote
