10-23-2024, 01:59 PM | #1 |
Dumb question?
So I'm prepared for the flames, but I was thinking... If a 402BBC uses 4.125" pistons, can you put them in a 400sbc? Or is the pin height wrong?
10-23-2024, 05:26 PM | #2 |
Re: Dumb question?
Answer #1 - yep; dumb question.
Answer #2 - OK, not really because the reality is with enough time, talent and resources a person can do anything (like use Chevy pistons in a Pontiac, or installing pistons backwards to change the rod angle). The real answer is is depends on all the other criteria that go into designing a piston: pin height, pin diameter, ring land, ring thickness, number of rings, floating pin vs press fit pin, dome vs no dome, valve relief size and location, static compression, stroke, how far down in the hole, etc. All that is in addition to just bore size. https://diamondracing.net/if-9-custo...rder-form.html So - if you can answer all those, then you have your answer. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 10-24-2024 at 06:51 AM. |
10-23-2024, 05:29 PM | #3 |
Re: Dumb question?
I never ever considered ring count and dimensions. That's a big variable. I assumed if it fit in the hole, it would just be a matter of finding the correct length/diameter rods. I'm certainly not an engineer, but I assumed it wasn't possible due to not finding ANY reference to it on the entire internet. I just wanted to know why. Thanks for explaining it.
10-23-2024, 06:56 PM | #4 |
driving is in my blood
Re: Dumb question?
Valve reliefs in the pistons would be in the wrong spot/size.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
10-27-2024, 10:56 AM | #5 |
Re: Dumb question?
No such thing as a dumb question.
There are a LOT of things to consider for pistons - pin height, compression height, crank counterweight clearance, etc. In the end...mixing and matching parts takes a lot of thinking It can sure pay off...like the brilliant guy that looked at a 400 crank and a 350 block and came up with the 383. The JE Pistons custom order form helps think through this if you think you might have come up with a workable combination. https://www.jepistons.com/custom-pis...ns-order-form/ |
10-27-2024, 11:19 AM | #6 |
Re: Dumb question?
Not with out massive work, and even then it is likely not be possible.
Piston pin locations or height are to different as is the valve lay out. It could work if you have a tall deck block where you could mix and match to find a combo. With SB2 style heads which are about as close to porcupine bbc heads as I am aware. Even with the short rods the 400 cam with. Much less 5.7's the pin is nearly in the oil control ring. Which with 6's i think it behind them. DSS pistons makes custom pistons at a reasonable price. |
