Old 10-27-2024, 04:01 PM   #6
dieseldawg142
dieseldawg142's Avatar
Re: aftermarket fender flares
just went thru this a couple months ago.
spent countless hrs looking for a set like what you want and there is not much out there for gmt 400's.
not super crazy about the bushwacker flares, i have a set of cut-out flares on my crewcab and there not really durable in my opinion. there thin and have a tendency to crack around the bolt holes.
hit up marketplace and go for a set of oem flares. of course they fit perfectly and are waaaay more durable and thicker than aftermarket.
i snagged a full set (used) for $150. if your careful and use a small screwdriver you can bend the wire springs off the flares so you dont have to try reach in the fender holes or take the fender off. me and my son had all 4 off in about 20 mins.
they use the factory holes in the fender lip and we also put 3M sticky tape where they rest on the body. stops movement and paint wear and holds them on super tight. we slapped some bed liner on ours and they look pretty darn factory
Size:  47.8 KBName:  IMG_3188.jpg
Size:  38.9 KBName:  IMG_4225 (1) (1).jpg
dieseldawg142 is offline   Reply With Quote
