Re: Radio antenna
cleaner look work pretty if you're in area that has good radio waves outside of town can be spotty you can buy inline booter in. the better taller fender antenna will all was pick weaker station. If you pretty far out town and far from towers some trouble now, then you may not like the glass mount antenna. I hope this helps
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
| Bookmarks |
