Old 10-15-2024, 06:41 PM   #1
Montierth
Montierth's Avatar
Differential swap out options
I currently have a 1970 GMC with leaf springs, 5 lug, disc brakes, non posi, 12 bolt differential with 3.08 gearing. I am interested in having a 3.73 gearing with posi/limited slip and keeping the 5 lug and disc brakes. I have looked into different options and seems like easiest would be to find a used differential that is already 3.73 and posi. Also, in the future I would like to convert to trailing arms. I have read that somewhere around 1970 the GMCs differential was a little different size than the Chevys?
My question is what would be a simple bolt in? Are there certain years that work better?
I found a 1998 10 bolt 3.73 posi differential someone is selling but I would have to buy 5 lug axles. Not sure though if it would fit.
1970 GMC C1500 short fleet
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 1970 GMC C2500 Dually Flat Bed
- 2003 Silverado
Montierth is offline   Reply With Quote
Old 10-15-2024, 08:34 PM   #2
Pep01
Junior Member
Re: Differential swap out options
I have a 69 with leaf springs. Also interested in this answer.
Pep01 is offline   Reply With Quote
Old 10-16-2024, 11:42 AM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Mid year 1970 the axle length is longer than the early model. You can pull 5 lug axles from 71 and up and slide them right in to replace the 6 lugs. Trailing arm conversion is going to be a little more interesting to complete. If you want to change the diff, look for a 12 bolt in an early square and bolt it in. You do have to fix the shock mounts locations/possible park brake cable replacement. Axles can move between coils and leafs, but it is not just a bolt in. Mounting perches have to be done and adding or subtracting a panhard bar.
Best option to me is to re-gear your current axle. You have a lot of shops near you unlike me (I do it all myself). I'd pull the axle, clean it and drop it off. 3.73 from 3.07 will have the Gas Gauge doing the Electric Slide faster than it used to do it.
No matter which way you go now, the axle issue is going to come up twice to solve if you do a suspension change.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 10-16-2024, 12:54 PM   #4
Montierth
Montierth's Avatar
Thanks for the reply. I realize it will be work with relocating perches, shocks, possible drive shaft length, etc. You are probably right about just regearing. I have thought about regearing and posi myself - I have done everything else on my truck. Read a lot and watched a lot of videos on how to DIY and there would be a few areas of challenge for me as well as just screwing it up and now out a rearend. I think it would be funner to go with the posi/3.73 gearing but really not necessary and find I can easily cruise on the freeway going to Dino's Git Down going 75-85 mph keeping up with crazy fast AZ drivers! So I guess what I mean is I don't want gear changers remorse. Almost would like to have a 2nd differential so if I ever wanted to go back to the 3.08 it would just be my time.
I slid under the truck and got a rough measure of 59 inches from the inside of the mounting plates. Would an early square bolt right in if I kept leaf springs?
Smitty
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 2003 Silverado
Old 10-16-2024, 09:46 PM   #5
71meangreenc10
If you have never been trained on how to rebuild a rear diff, I would not do it. Please do not watch videos on it, it just aint that easy. I have built a many 12 bolts and there are a lot of ways to mess it up. A ton of people do not know how to read gear tooth patterns and that is where you will mess up along with preload requirements on bearings. I have a whole drawer just for diff special tools. Crush sleeves aint nobodies friend either. I could go on and on about this subject...
I have a 74 squarebody leaf unit on my 68 stepper. Only change was the shock mounts. Everything else was the same. Have to think if the park brake cables matched (probably didn't). I can measure it tomorrow if you like, it will be a while, I got to go pick up O-G in the morning about 400 mile trip.
Talk to Tom Korinek in Mesa. He may have what you need on the ground already. He is on here (TKorinek) send him a message.
Smitty
71 C30 Wrecker
Old 10-16-2024, 11:57 PM   #6
Montierth
Montierth's Avatar
Thanks for talking me off the ledge. I get it. I'll probably just keep looking for another diff or save up to have mi e professionally done.
Smitty
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 2003 Silverado
Old 10-17-2024, 12:35 AM   #7
71meangreenc10
No worries.
Smitty
71 C30 Wrecker
Old 10-21-2024, 12:02 AM   #8
MikeB
MikeB's Avatar
Smitty
Yes, it would be a lot less painful to simply change the gears. In addition to making the gas gauge pointer drop quicker, 3.73 gears will make your tach pointer move 21% higher at any given road speed, and highway driving will not be fun, unless you have an OD trans.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 10-21-2024, 12:40 AM   #9
Richard
You should use a gear that provides the performance and comfort you desire. IME any gear change will not change milage. Have a 94, and 2000 as well as my current 72. Also had a past 72 my first vehicle. The 94 and 2000 currently driving vehicles average 13-14 MPG. I expect the same with the LSA swap in my 72. Both of my 72's averaged 10 MPG empty or loaded. The original longbed 3/4 ton had 4.10's and the current 1/2 ton shortbed had 3.73's when a driver. Did the gear change in my 94 a while back because of a failure, my first diff ever 3.42 up to a 3.73 and no milage change. Just better performance. Was not really difficult, but I attempt a lot of stuff some may say is difficult.
Richard
Old 10-21-2024, 02:18 AM   #10
mr48chev
mr48chev's Avatar
This brings up some questions and back ground info on this truck.
As 1/2 ton 70 trucks were all six lug and drum brake be it either Chevy or GMC With no listings in parts catalogs for disk or 5 lug for 70 what's the scoop?
Historically Chevy came with the trailing arms and coil springs while GMC came with leaf springs but either could be special ordered the other way from what I understand.
If you were close enough I have a trailer made out of the back end of a 70 C10 Frame from a truck I rolled in 1989 that has all the coil spring pieces except the axle. I sold the axle after I totaled the truck and stuck the old axle from the guy I sold it to's truck under it. A very worn out stump pulling geared 66 axle. I've thought about putting the trailing arms under my 48 but the jury is still out on that.
My ongoing truck projects:
Old 10-21-2024, 02:18 PM   #11
68Gold/white
Montierth,
Hard to remember how to spell your user name...LOL
It sounds like you already have a lot of good going your way. You 70 has been converted to 5 lug and disc.
I advise folks to buy a 71 or 72 if they like this era of pickup, just because they already have front 5 lug disc. Conversion is not that difficult for many of use, but a hassle for folks less mechanically inclined, that just would like to enjoy one of these pickups without working on them. I've seen many of these that are real nice that still have the dreaded front drum brakes still on them....I have a 67 and 68. Both will be 5 lug disc when they are roadworthy again. I am using factory parts.
The gear ratio is an important thing. In the olden days you just ran what you had. The 3.07 and 3.73 are the most common gears in these pickups (I think, anyone?)
I read here, sometime back that the factory ratios available were 3.07, 3.42, and 3.73 (there were others, but I don't remember, these were numbers I was interested in. I recently purchased a 3.42 set. Is a great gear for overall driving performance or cruising. MPG's won't be the best, your driving desires can dictate the gear you want.
I understand your desire for rear coils. Both my 67 and 68 have rear coils. I've been doing a lot of work on a friends 71 C-10 LWB. It has rear leafs. I see no undesirable driving characteristics in it. It's a boatload of work to change to coils. Might be easier to buy a coil spring chassis and swap your stuff over. Your leaf spring rear endd connt be (easily) converted to coil spring use........
68Gold/white is offline   Reply With Quote
Old 10-21-2024, 04:48 PM   #12
MikeB
MikeB's Avatar
Originally Posted by Richard View Post
IME any gear change will not change mileage.
Well then, GM must have made a huge mistake going to the 700R4 OD trans, or those crazy gear ratios like 2.41 and 2.56 thinking it would help them meet CAFE standards.
Mike
Old 10-21-2024, 05:16 PM   #13
dagnabbitt
dagnabbitt's Avatar
I have a 1970 SWB trailing arm truck, and I have been interested in a similar question to OP's. My truck had the G80 option on the SPID, but that appears to be long gone, now. Its a one-wheel peeler.
The reason why I would be interested in swapping an entire axle is to kill two birds with one stone: getting posi while also going to five lug.
Are the 73 and up rear assemblies that much different from the 71-72? If I am reading correctly it sounds like it is just the axle perches that may be different?
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 10-21-2024, 10:34 PM   #14
Accelo
Accelo's Avatar
It was bad, but not as crazy as one thinks. The later the transmission, the lower the first gear.
I had a 2006 Corvette with 2.73:1 standard rear gears. It also had a 6-speed with double overdrive. The 6th gear had a 0.57 ratio, and the final drive ratio was 1.56.
It would pull a 5 Deg sloped hill without shifting down, in Drive, at 1400 rpm in 6th.
A light car with 400 hp helped. The dog engines of the 80s and 90s definitely struggled with the high ratios.
Accelo is offline   Reply With Quote
Old 10-25-2024, 10:54 PM   #15
53burb
53burb's Avatar
sent you a Pm....
53burb is offline   Reply With Quote
Old 10-30-2024, 01:41 PM   #16
ullose272
tire diameter of probably 26" helps as well
ullose272 is offline   Reply With Quote
Old 10-30-2024, 02:47 PM   #17
pjmoreland
pjmoreland's Avatar
The posi in the 1998 unit is likely a Gov-Lock style of posi that has a centrifugal engagement mechanism that activates once there is a significant enough difference in RPM between the left and right axle shafts. It will then disengage at speeds over 20mph or so. I put one in my 1989 K10, and it worked well for me while doing some four-wheeling in Moab, UT a few weeks ago.
pjmoreland is online now   Reply With Quote
