11-04-2024, 11:53 PM | #151 |
Re: 1971 K10 Stepside - Getting a Roller Roadworthy
Painted the perches
11-04-2024, 11:57 PM | #152 |
Very nice welds.
11-05-2024, 12:39 AM | #153 |
11-05-2024, 05:56 AM | #154 |
I can't weld at all. Wish I did.
11-05-2024, 09:58 AM | #155 | |
Love the consistent progress you're making.
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
11-05-2024, 10:55 AM | #156 |
11-06-2024, 12:34 AM | #157 |
Installed the front carrier and pinion bearings. Thankfully, my wife is entertained when I "cook" car parts.
11-08-2024, 12:12 AM | #158 |
Cleaned up the rear leaf springs and u-bolts with a wire wheel and then painted them. It appears that there is a GMC logo on the u-bolt saddles.
11-08-2024, 12:13 AM | #159 |
U-bolts and retainers
11-08-2024, 08:22 AM | #160 |
3824491 dates back to model year 1963 and was used through 1972.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
11-08-2024, 10:38 AM | #161 |
Interesting. I did a search on the part number, and I saw a thread that says these cast pieces like to break in half. I'll take my chances for now, but I should probably replace them eventually.
11-08-2024, 01:16 PM | #162 |
Yes, I have broken one. When tightening them, you must tighten slowly and evenly or they will easily break. My donor Blazer supplied another one for the project. 1967-68 trucks did not use these.
11-09-2024, 12:28 AM | #163 |
Reattached the rear axle to the leaf springs.
11-10-2024, 01:48 AM | #164 |
Spent some time working on the front axle today. Cleaned some rust out od the inside of the housing. Gave the outside a quick cleaning with a wire wheel and sprayed some paint on it. There was a decent sized dent in the diff cover that I straightened out using the Hydraulic press. That cover is thick.
11-10-2024, 01:49 AM | #165 |
More photos
11-10-2024, 01:52 AM | #166 |
Also cleaned up and painted the rear brake components with high-temp paint.
11-10-2024, 04:12 AM | #167 |
Dude, you're an Artist. You sculpt Chevy Trucks out of rusty steel.
11-10-2024, 08:06 AM | #168 |
Nice work on rebuilding those differentials Patrick !!!
I just completed doing both of mine and it's a lot, but you made it look quick & easy... Amazing progress !!! Keep it going. Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
11-10-2024, 10:49 AM | #169 |
11-10-2024, 10:53 AM | #170 |
The way the shims go behind the bearings on this Dana 44 looks like a real pain compared to a 12-bolt. It would be nice if everything is still in spec using the same shims, but I doubt I'll be that lucky.
11-10-2024, 08:31 PM | #171 | |
Seriously -- wear safety glasses.
11-13-2024, 12:45 AM | #172 |
It's chilly outside this evening, so I wasn't very excited to be out there laying on the asphalt, but I went ahead and did it anyway. Got the front differential reassembled. The pinion preload and the carrier backlash are good. The carrier preload is good and tight. The gear pattern could be better, but I can tell that it matches the wear marks on the teeth, so I'm not going to mess with it. It feels smooth when rotated.
11-13-2024, 12:47 AM | #173 |
More photos
11-13-2024, 12:48 AM | #174 |
Last photo
11-13-2024, 07:22 AM | #175 |
Those shims are a PITA... I honed out a set of bearings & races to a slip fit to mock-up the gear pattern. I was changing the gear ratio so the shims were totally different. It was still a PITA.
Good looking work. Gary
