Old 11-07-2024, 07:33 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Help with Cab reassembly.
Originally Posted by jumpsoffrock View Post
I dragged my feet for three years and recently I have had to abandon the "gentle reconditioning" of my truck and disassembled cab.
I need to slap it together and make it driveable--simple as that.
The cab is repainted poorly and all the parts that came off of it are ready in boxes.
Where should I start as far as reassembly order?
Thank you very much.
Edit: The truck is NOT being sold, I need it as a work truck ASAP.
A good paint job dude.
Kidding aside, square up your cab. My 71 is nearly a can't miss, very little play. Some considerations, such as the cushions u use, I've only used rubber. Snug up cushions to lowest torque setting at most, imo, you'll finish torque when satisfied with the assembly. Compare cab to bed....doors, core support snug only, finish that after cab and fenders r good. Slow and methodical, back and forth to happy. I'm no expert however, done it once. Approx. 3 16th even gaps, doors top front will b less.
Lots to a full cab assembly. But perhaps there is a start.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
