Old 11-10-2024, 10:41 AM   #351
raggedjim
raggedjim's Avatar
Re: Previous owner '68
Parts, pieces, pieces, parts.
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 11-10-2024, 10:43 AM   #352
raggedjim
raggedjim's Avatar
And it just keeps on leaking!
Roger
'70 GMC Jimmy 2wd
Old 11-10-2024, 10:46 AM   #353
raggedjim
raggedjim's Avatar
Hi-tech organization system.
Roger
'70 GMC Jimmy 2wd
Old 11-10-2024, 10:51 AM   #354
raggedjim
raggedjim's Avatar
Case is close to being empty.
Roger
'70 GMC Jimmy 2wd
Old 11-10-2024, 03:53 PM   #355
zicc1835
zicc1835's Avatar
I thought I read that you needed this experience the way your going at this looks like you are getting what you asked for ...I wouldn't think of rebuilding a auto trans but now you got me starting to turn your way I have a motor and trans in waiting ...for rebuilding but need to finish my current build ...great progress on your project
zicc1835 is offline   Reply With Quote
Old 11-10-2024, 05:02 PM   #356
raggedjim
raggedjim's Avatar
Trust me, I'm tearing it down and replacing whatever is in the kit but I have a very rudimentary understanding of what the hades is going on in this thing! And I am getting experience! If all goes well I have another one to do for my Pontiac.
I do have a book! But I'm also taking lots of notes which means I'm going slower than a real mechanic would.
I like trying to rebuild things. I was going to rebuild the waterpump but the kit cost more than a new one.
Roger
'70 GMC Jimmy 2wd
Old 11-10-2024, 06:50 PM   #357
raggedjim
raggedjim's Avatar
Took the case to the carwash and sprayed the crap out of it. Looks pretty clean and feels good to the touch.
Roger
'70 GMC Jimmy 2wd
Old 11-10-2024, 06:53 PM   #358
raggedjim
raggedjim's Avatar
Found a worn bearing surface on the output shaft ring gear. Not sure if a tranny guy would go ahead and use it, but I have another one coming in. Every thing else is looking good so far.
Roger
'70 GMC Jimmy 2wd
Old Yesterday, 10:07 AM   #359
loudchevy
loudchevy's Avatar
Awesome posts! Never opened one up before and like yourself have a very basic understanding of how it all works. One of these days I'll tear open a TH350 and do this same thing.
I would've replaced that part as well. Might as well while you have it blown apart. Looking forward to seeing it go back together.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old Today, 10:59 AM   #360
raggedjim
raggedjim's Avatar
If you find one cheap enuff, or even free is better, then I would go for it. There are a couple of tools that help, I'll try to take a picture of them.
The book I have has a few weak areas, but I am also checking the web as I go. Here's a pretty good thread I found. https://nastyz28.com/threads/first-t...-wrong.325954/
Roger
'70 GMC Jimmy 2wd
