Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 11-11-2024, 11:41 AM   #5951
Lost in the 60's
Lost in the 60's's Avatar
Re: What did you do today not on your truck...
Can only post 5 pics...
Lost in the 60's is offline   Reply With Quote
Old 11-11-2024, 11:44 AM   #5952
Lost in the 60's
Last batch. Changed the last pic. This is how the Harley gets strapped in. After I had this worked out, I cut the excess off and melted the ends to prevent fraying.
Old 11-11-2024, 12:38 PM   #5953
Boog
laying low
Boog's Avatar
Real nice setup. The conduit is a great idea for all exposed wires. Mice love to chew the wires especially on something like a trailer that sits unused a lot.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-11-2024, 12:40 PM   #5954
D.B
D.B's Avatar
I went to the track to try out my new motor in the S10. Had a great time. Scary at first but finely got it to go straight.
Darrell
1972 Cheyenne Super C20 (My Fun Drive)
2000 S10 Xtreme (My Drag Truck)
D.B is offline   Reply With Quote
Old 11-11-2024, 03:12 PM   #5955
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Thumbs up Re: What did you do today not on your truck...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 11-11-2024, 05:58 PM   #5956
HO455
HO455's Avatar
V8 S10's are great! Yours is looking good. Any more information on it?
RIP Bob Parks.
Old 11-11-2024, 07:27 PM   #5957
Rickysnickers
His build thread, https://67-72chevytrucks.com/vboard/...d.php?t=841196
Old 11-11-2024, 08:23 PM   #5958
D.B
D.B's Avatar
Originally Posted by Rickysnickers View Post
Thank you for posting my build.
Darrell
Old 11-11-2024, 08:30 PM   #5959
D.B
D.B's Avatar
It's a 2000 Xtreme. This is the third motor in it. Each one got a little nastier. First engine was a 383 with just over 500hp. The second motor was a built 374 with just over 600hp. Now this third motor is a built 430 with just over 700hp. I put this truck together to handle more than 1000hp just in case I decided to go bigger. So, all I really had to do was build the motors, the rest of the truck was fine, very little change.
Darrell
Old 11-12-2024, 07:36 AM   #5960
4u2nv
Go fast and look good doing it
What a weapon you got there
4u2nv is offline   Reply With Quote
Old 11-14-2024, 10:49 PM   #5961
Sheepdip
Sheepdip's Avatar
If you have never changed a battery in a 2020 Tahoe (I'm sure a few other models too) your in for a real treat.
The wife's original factory battery finally gave up the ghost the other day so I found out the task of changing it is no longer a simple operation lol. You have to completely remove the air cleaner housing then loosen and slide the coolant overflow tank forward to have room to get it out.
It has a positive and ground distribution block that straddles the top of the battery with 5 cables attached, all of that plus a brace over the battery.
Nothing overly difficult it's just not a 15 minute job anymore.
Sheepdip is offline   Reply With Quote
Old 11-15-2024, 09:49 AM   #5962
Rich84
Rich84's Avatar
Did you have to do something to maintain power to the computers while you disconnected the battery? I think some vehicles require it.
Rich84 is offline   Reply With Quote
Old 11-15-2024, 12:08 PM   #5963
Sheepdip
Sheepdip's Avatar
From what I know/experienced it's only if you want to save all the programing you did to the radio, A/C/Heat etc ...the wife took care of that after the fact.
I did watch a youtube video (hoping for a shortcut) which showed turning the battery on its side for removal without taking everything else apart (coolant/air box) but it did not work for me as I was afraid of snapping the plastic mounting tabs on the coolant tank off, then we have another problem.
On that distribution panel/busbar that sits on top of the battery it has a blue multi-wire connector it feeds that appears to power the computer, you can leave that connected as I did, and I suppose connect remote 12 volts to it but it would be right in the way of what your trying to do IMHO.
Old 11-15-2024, 02:13 PM   #5964
72c20customcamper
72c20customcamper's Avatar
Changed the engine oil on the Kubota . Not all that exciting
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 11-15-2024, 03:15 PM   #5965
Louisvillekytruck
Originally Posted by dave6672 View Post
Not too many truck parts, but I did come home with a cool 72 truck first aid kit as well as a 68 truck data book and a 71 truck data book.
Looks like a great time dave.
Louisvillekytruck is offline   Reply With Quote
Old 11-15-2024, 08:48 PM   #5966
Lost in the 60's
My 2011 Silverado has a brace right over it too, that has to be removed. I don't need to move anything else though, but I did use a jump pack on the bus bar and negative to the engine block to maintain all presets, as I wouldn't have a clue how to get all that crap running the same way again.
Old 11-15-2024, 09:22 PM   #5967
Steeveedee
Who Changed This?
Steeveedee's Avatar
There's a gizmo one can buy at the parts store that uses a 9 volt battery, and plugs into the electrical system. It has enough energy to keep the memory alive until the battery is switched out. I have my batteries tested when they've been in our vehicles for awhile, just to see where they are at. I'd rather replace a battery early than have my wife stranded someplace because I wanted to squeeze the last electron out of a battery. These days, batteries do not fail gracefully. Used to be you could tell, when the engine started cranking over a bit slower. Now, you drive someplace and come out to a failed battery. Come to think of it, it's time to go through the rotation with our vehicles having the batteries tested.
~Steven
Simi Valley, CA
Old 11-16-2024, 10:53 AM   #5968
Rickysnickers
After many months of my bike sitting in pieces, I got it back together. I installed some silicon coolant lines to replace the 26 year old rubber ones. The body work needs to be installed still. Now I just wish I could ride it
Old 11-16-2024, 04:29 PM   #5969
Boog
laying low
Boog's Avatar
It'll help you look forward to spring.
Boog
primer is finer
Old 11-16-2024, 06:07 PM   #5970
Sheepdip
Sheepdip's Avatar
Exactly what happened! Once that computer drops below 10.5 volts or so it shuts it all down, couldn't start it even if cranked slowly.
Old 11-17-2024, 07:08 AM   #5971
4u2nv
Good lookin bike
I call them organ donors
Old 11-17-2024, 10:21 AM   #5972
Rickysnickers
No probably not. I have a health condition that makes it very difficult to ride the bike. I only get to start it up and listen to it.
Old 11-18-2024, 01:47 PM   #5973
72c20customcamper
Did some splitting today. This I did by hand with the Fiskers X27
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 11-20-2024, 05:51 AM   #5974
BRL
BRL's Avatar
Massive power outage?
Who cares.
Tested the ol' lawnmower generator and it's fine.
I have a spare Chevy alternator charging two spare car batteries in here with a pure sine wave inverter to keep the ice cream frozen and the wifi on so I'm all set.
BRL is offline   Reply With Quote
Old 11-20-2024, 07:07 AM   #5975
Getter-Done
Getter-Done's Avatar
Who cares.
Glad that your are Prepared.
84 Chevy K-20
