Yesterday, 11:11 PM | #1 |
Need way quieter exhaust now...
I built my exhaust using the Flow Master Delta 44s in 3.
The mufflers are under the box, not the cab. I had the original Flow Master 40 Series in 2 1/2 before on the old engine, which had the mufflers under the cab, and out the sides, just in front of the back tires, and it was way quieter. I thought the Delta 44s were gonna be quieter, but aughhhhh...no. I want quieter exhaust...I can add cutouts if needed. The wife is not too keen on going for drives when its this loud. Any recommendations? PS: I used v-bands on the muffler inlets and outlets, so it should be easy peasy to change them out.
"If it ain't broken, fix it 'till it is!" |
Today, 01:23 AM | #2 |
Re: Need way quieter exhaust now...
I've heard that Dynomax Super Turbo are nice compared to most.
Today, 09:45 AM | #3 |
I am enjoying my Magnaflow 11266 mufflers. They are on a Blazer with the top off. I have 3 exhaust.
Today, 09:56 AM | #4 |
I thought that I went with 3 exhaust but actually it is 2.5.
Today, 10:51 AM | #5 |
Active Member
I purposely designed my own exhaust system to place the mufflers further behind the cab on a long bed K10. I also went with Magnaflow in a 4" x 9" (11225, 2.25"). I was amazed at how quiet it was. That was a great idea on the V-bands. I thought of welding those in at the collectors.
Today, 10:53 AM | #6 |
Another vote on the Dynomax Super Turbo mufflers. My dually has 1 3/4" long tube Chevelle headers into 3" head pipes w/a H-crossover to the mufflers. I used reducers to go down to 2.5" tailpipes & they exit @ the corners of the bed/bumper.
Today, 11:56 AM | #7 |
Where do the pipes exit now? Any exhaust that exits under the truck will rattle your brains out, not to mention when you leave the pavement you look like a helicopter landing.
Today, 02:01 PM | #8 | |
He ran 4 Chrysler Imperial turbos. Mufflers just like the turbo max. He had room for 4 in a smallish car. Maybe you do to. |
Today, 03:10 PM | #9 | ||
-did not want them out the back and passing by the fuel tank. -did not want down drafts as my back alley is dirt. (I spend enough time cleaning and polishing this thing.)
"If it ain't broken, fix it 'till it is!" Last edited by Extended Power; Today at 03:16 PM. |
Today, 04:44 PM | #10 |
Easiest way to quiet an exhaust is to add a crossover. Makes a huge difference.
Today, 05:13 PM | #11 |
My vote is for the Dyno Max turbos. Biggest you can fit length wise.
Today, 06:01 PM | #12 | |
I added an H pipe off long tube 2 1/2 out back through MagnaFlows under bed. It's only loud from the back...in cab noise is not bad. -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
Today, 07:06 PM | #13 |
>> had the mufflers under the cab, and out the sides, just in front of the back tires, and it was way quieter.<<
That setup had longer pipes AFTER the muffler. Short pipes after the muffler are always louder. Changing the muffler with the same short pipe and what looks like a megaphone tip will change very little, regardless of the muffler choice. You could consider running the pipes over the axle and out the side behind the tires.
'67 GMC 2500, 292, 4spd, AC |
Today, 07:12 PM | #14 |
I liked my Flowmaster Delta 50 series. They were quiet to mild inside, but let you know on the outside they mean business. The ones on my 70 are real quiet, too quiet, but not sure what Generic brand my friend had put on when he had them done 10 years ago.
Today, 07:33 PM | #15 | |
70+ ( Old Skool Club )
https://www.dynomax.com/catalogsearc...esult/?q=17747
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Today, 07:50 PM | #16 |
SpinTech Sportsman XL have a nice note but are not loud
