12-04-2002, 02:03 PM | #26 |
67-72 Addict!
Blue 69,
Thanks for taking the time to share this info with everybody!. Will this switch make my wipers FASTER or just intermittant?. As I said mine are super slow........Jim
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
12-04-2002, 02:18 PM | #27 |
GYRO GEARLOOSE
Here is a helpful diagram of standard auto relays. A coil is used to 'pull' a switch. The switch can switch on power, or complete a ground, as it is doing in the wiper circuit. Wiper motor gets power at all times. On our series motors, there are 3 possible combinations, plus washer operation. For you techies, here are the combinations:
Park and off = lt blue and black connedted, (not grounded0 low speed = lt blue and black grounded high speed = lt blue grounded washer = dark blue grounded
Nevada City, CA Everett, Washington 57 3/4 rat, 235, 3spd 66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring 68 C10 LWB 350 4spd, 4.56 rear dump runner 82 Camaro, 305, THM-200-R4 84 Monte Carlo 305 TH350, land tuna 85 Tercel SW, snow runner DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB |
12-04-2002, 09:02 PM | #28 |
blue_69, what was that part #?
12-05-2002, 12:58 AM | #29 |
"Trucks with Class"
If you build it, they will come!
I would sure like to see you put the complete package together and make a few bucks for your time & knowledge. I sure don't want to run around trying to find this stuff.
OK, I get to ask one dumb question: Does it park in the Off/down position? I had an after market kit that was just timed & stopped where ever it was when the time ran out. If it was in front of your face, you had to tap the horn to get it to move a little farther out of the way. LOL. J.C.W. special. |
12-05-2002, 12:58 AM | #30 |
Designated Grumpy Old Man
The Cole-Hersee part # is 75600-04. I checked with a couple of parts dealers and they go from the low of $44.00 to the high of $60.00.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
12-16-2002, 04:24 PM | #31 |
bosch relays
IS anyone going to package a intermitent switch setup? I'm not a relay expert, are the 3 relays shown in addition to Bus intermitent switch? Where should they be mounted? Maybe I'm missing the update somewhere else. The rain is really starting to fall on West coast now!!
Bob |
12-16-2002, 06:22 PM | #32 |
I WOULD SURE LIKE TO BUY ONE OF THESE KITS, WHEN THEY ARE PUT TOGETHER. PUT ME DOWN FOR ONE.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
12-16-2002, 08:41 PM | #33 |
454 club
good job and much needed info
David 1965 Chevrolet c-10 454 automatic Custom bbw swb. 1965 Chevrolet C-10 swb (Sold) 1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's. R.I.P "I will miss you. 1967 Chevrolet C-10 6 Cyl Custom lwb 1939 Chevrolet Coupe, 350 v8 automatic. 1935 Chevrolet 2 Dr Standard in the works. 2015 Harley Davidson Street Glide. 2023 Chevrolet Stingray Z51 Convertible. I never want to grow up. |
12-17-2002, 11:07 AM | #34 |
I would love one too....I'm not an engineer, so as long as it's pretty simple to install!!!lol.
09-09-2013, 05:13 PM | #35 |
Re: update on intermittent wipers
I am new to the forum but I have learned a great deal from you guys in rebuilding my 72 K20.
I followed your wiring diagram but what I get is fast wipers at key on with the switch off. I can rotate the switch to fast and the wipers go to slow speed. What did I do wrong? Thanks for the help. John |
11-12-2024, 11:33 PM | #36 |
Raising this thread from the dead to update, I believe the part number he used is Cole Hersee 75601-06
Just FYI, they made several versions of essentially the same exact intermittent-hi-low wiper switch with several different but similar part numbers, some of them had different color wires, some had more wires than others, and they all had different plugs, and some had no wire plug at all--just loose wires. This handy PDF gives you build specs of all of the different variants of this switch, and if you look back to blue_69 original wiring image, you'll see he was most likely using a 75601-06. https://peerlesselectronics.com/medi...s/75600-02.pdf You can most likely substitute any one of these switches and make it work if you wire it correctly. |
11-13-2024, 10:38 AM | #37 |
The Older Generation
It's a shame this didn't go any farther. He hasn't posted since 2016, and hasn't been on the board since 2018.
11-13-2024, 12:30 PM | #38 | |
Heck, I sent the intermittent wiper set-up I purchased from another thread to board member 68bowtie4x4 in hopes he would be able to build these for others & that stalled out. Sure seems like a good idea.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-13-2024 at 10:11 PM. |
11-13-2024, 02:23 PM | #39 | ||
"I ain't nobody, dork."
I have an ancient aftermarket wiper delay in my '70 CST/10 that my Dad wired in eons ago. It finally quit working last year, and in the box of parts I got from my Dad with the truck, was a Ziploc bag with a new exact duplicate of one of these units. But Dad had it mounted below the steering column and it was always a pain to use. I'd like to try and make one of these cole hersee switches work. Too bad this thread died short of it's goal.
Gary
11-13-2024, 02:39 PM | #40 | |
I find it odd there has been multiple companies that created 1pc window kits for these trucks yet don't see a market in updating items that can significantly impact the 'drive' in them. Sure, 2spd wipers get it done but those of us who have put miles on them regardless of the weather know the intermittent option would be gladly welcomed.
11-13-2024, 02:49 PM | #41 | |||
Gary
11-13-2024, 05:48 PM | #42 |
You could try contacting twouvakind, he built a lot of plug and play delay modules. I bought mine from him in 2016. I see his last activity on the board was back in January of this year. When I was looking to buy one it did take a little while to hear from him, but he got right on it and made another "batch". If he is no longer making them, you can buy all the parts and put one together yourself, but give him a try first, it will, save you the hassle of sourcing the delay board and potentiometer plus connectors.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
11-13-2024, 05:58 PM | #43 | ||
@Orange Crate Appreciate it man!
Gary
11-13-2024, 10:00 PM | #44 |
Deleted post.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-13-2024 at 10:14 PM. |
11-14-2024, 02:49 AM | #45 | |
11-14-2024, 03:31 PM | #46 | ||
Alotta OG's in this ancient thread.
Gary
11-14-2024, 08:21 PM | #47 |
I see LMC is now selling an Intermittent Wiper Module:
P/N: 36-0902......$72.95 I don't know if this is the original Cole-Hersee device, or more likely they got hold of an example and sent it overseas to pirate their own version. I have no experience with this iteration, and wonder if anyone else has?
11-14-2024, 09:28 PM | #48 |
I doubt the LMC unit has been hacked from the unit twouvakind was putting together. His had an infinite delay between 3 seconds to 30 seconds. See below for the LMC discription.
"This wiper module provides intermittent settings for 3, 5 and 8 second delay intervals" I think I paid $60 plus shipping for mine in '16. Which is a great deal when you consider just the logistics of putting a number of these units together. The delay board is $12 and the extended shaft potentiometer is about $6 plus rolls of good wire, connectors and case. That's about $25 just in parts without the 2 hours to assemble. I would keep trying twouvakind just because he made all the other ones almost for no profit (maybe he has better things to do now...)
11-14-2024, 11:34 PM | #49 |
Seems a profit should be made. People should be paid appropriately for their time & efforts/knowledge invested. I certainly have no issue w/paying.
