Old 11-25-2024, 09:13 PM   #1
Ricky Rodder
Ricky Rodder's Avatar
The Mueller 69 Blazer
I'll just put these here. Actually I have been deep into this, for several weeks now. It's really looking fantastic and so I have decided to start this thread.
Ricky Rodder is offline   Reply With Quote
Old 11-25-2024, 10:12 PM   #2
Ricky Rodder
Re: The Mueller 69 Blazer
Backing up a few. This is what arrived. Basically, a windshield frame, a firewall, and a patched floor. Now we know exactly what it needs.
Old 11-25-2024, 10:44 PM   #3
1970cstblazer
1970cstblazer's Avatar
The Blazer community is fortunate to have access to all the sheetmetal required to bring one back. Looking forward to your progress.
Old 11-26-2024, 08:09 AM   #4
Ricky Rodder
Thanks! Progress is coming.
Old 11-26-2024, 06:54 PM   #5
Ricky Rodder
The remnants left of the cab was media blaster to the white metal. Then a coat of epoxy primer was sprayed over the bare relic.
Old 11-27-2024, 07:44 PM   #6
dec010974
dec010974's Avatar
I didn’t know you could buy the front blazer tub like this.
dec010974 is offline   Reply With Quote
Old 11-27-2024, 08:08 PM   #7
Ricky Rodder
You can't. This is the result of spending hours trimming all the bad away what's left of the good.
Old 11-27-2024, 08:35 PM   #8
Ricky Rodder
Next a new rocker panel and rocker box for the passenger side was clamped in position and welded in place. From there, the firewall had its access holes covered with with pre design cover plates.
Old 11-27-2024, 09:53 PM   #9
dec010974
dec010974's Avatar
@ Ricky Rodder. Please continue to share this info. Thanks
Old 11-28-2024, 08:10 AM   #10
Ricky Rodder
I certainly will thanks
Old 11-29-2024, 07:39 PM   #11
Ricky Rodder
The welds were ground and dressed on the firewall filler plates. And then filler applied to smooth out the cosmetics.
From there a new bed floor was fitted into place, along with new bedsides.
Old 11-30-2024, 08:59 AM   #12
dec010974
dec010974's Avatar
What frame will you be using for your K5 Blazer tub?
Old 11-30-2024, 10:52 AM   #13
Ricky Rodder
It's undecided at this point
Old 11-30-2024, 01:11 PM   #14
dec010974
dec010974's Avatar
are you going with an aftermarket frame/chassis?
Old 11-30-2024, 04:11 PM   #15
Ricky Rodder
I don't know as of yet
Old 12-01-2024, 01:25 PM   #16
Ricky Rodder
This takes care of an initial fitting of the new sheet metal. Not bad, but things will need persuasion here and there. To get it all dialed in correctly.
Old 12-01-2024, 02:14 PM   #17
dec010974
dec010974's Avatar
Amazing
Old 12-01-2024, 02:21 PM   #18
dec010974
dec010974's Avatar
What are the Blazer Tub measurements from mount to mount. For instance, the first tub mount to the second mount? The second Tub mount to the third Tub mount, and son on? I'm curious about this information. Thanks in advance.
Old 12-05-2024, 06:17 PM   #19
Ricky Rodder
Things are lining up fairly well.
Old 12-05-2024, 11:15 PM   #20
dec010974
dec010974's Avatar
Looking Good. 👍
Old 12-06-2024, 08:10 AM   #21
1970cstblazer
Question Re: The Mueller 69 Blazer
Is that the chromed steel grille shell?
Old 12-06-2024, 02:11 PM   #22
Ricky Rodder
Amazing
Old 12-06-2024, 02:12 PM   #23
Ricky Rodder
Yes it is.
Old 12-06-2024, 02:54 PM   #24
1970cstblazer
Thumbs up Re: The Mueller 69 Blazer
Yes it is.
Looks like the fit is good. There is a member here that had issues with one of them.
Old 12-06-2024, 05:39 PM   #25
Ricky Rodder
It fits with some give and take persuasion. Just like all of the rest of the sheet metal.
