Old 11-28-2024, 01:00 AM   #26
jweb
jweb's Avatar
Re: Explorer 8.8
Got the QA1 front installed. Wasn’t impressed by the instructions or fit. Hopefully it aligns well and drives good.
1951 Truck, LS1/4L60
1964 Suburban, current project
jweb is offline   Reply With Quote
Old 11-28-2024, 01:02 AM   #27
SkinnyG
SkinnyG's Avatar
Re: Explorer 8.8
I love the amount of dynamic ackerman that's in there!
Straight impossible to get that with a factory crossmember. Should have a very nice turning radius, and responsive steering.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 11-29-2024, 10:35 PM   #28
jweb
jweb's Avatar
Re: Explorer 8.8
I hope you’re right. I had several issues installing this. I’m a little concerned with the steering setup. The angle on the steering rack seems excessive and the adjustment sleeves are all the way in. I’m hoping it aligns well and drives good. Won’t know for sure until I get an alignment, which will be quite a while.
Old 11-30-2024, 01:11 AM   #29
SkinnyG
SkinnyG's Avatar
Re: Explorer 8.8
When the steering rack is closer to the centerline of the wheel, dynamic ackerman increases. The angle of the steering arms in an indicator. More ackerman is always good. Put it this way: I am envious.
If the tie rods are adjusted all the way in, and you need more adjustment, cut the tie rods shorter by whatever you need to correct the adjustment. This is often done when installing dropped spindles (grin).
Old 12-02-2024, 11:56 AM   #30
jweb
jweb's Avatar
Re: Explorer 8.8
Thanks for the info, I was concerned about the rack angle but it sounds like an advantage.
I was also concerned about the rod end at the spindle since it requires 4 custom aluminum pieces per side, while the POL rack uses a stock tie rod. I believe these are in place to correct bump steer. I have a problem with bump steer in my 51 and I really want to avoid it on this build.
I will be using drop spindles and setting the Suburban as low as I can, my steep driveway will be the limit. Has to be able to get in the garage.
Old 12-02-2024, 04:11 PM   #31
SkinnyG
SkinnyG's Avatar
Re: Explorer 8.8
Bumpsteer is 100% determined by the location of all the pivots - ball joints, inner bushings, rack width and height. It's not always easy to change it.
Show me a straight-on front view of everything, and I can pretty much tell you if it's all in the ballpark or not. I am super passionate about steering and suspension (suspect Aspergers here).
Old 12-02-2024, 04:27 PM   #32
SCOTI
SCOTI's Avatar
Re: Explorer 8.8
Ackerman should also be able to (can?) be increased @ the steering arm depending on type of spindle. I don't know if the steering arm is cast in the exact same location between a dropped vs stock spindle.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-02-2024, 07:18 PM   #33
jweb
jweb's Avatar
Re: Explorer 8.8
I’ll try to get a pic of it from the front soon. Once this Suburban is done I hope to dig back into my 51. Just needs a few adjustments, mainly the bump steer. I really want to fix that since my wife will likely drive it once the Suburban is done.
Old 12-02-2024, 07:21 PM   #34
jweb
jweb's Avatar
Re: Explorer 8.8
That’s a good question about the steering arm at the spindle. Unfortunately I don’t have any stock spindles to compare. I do know that QA1 has some different spacers at the spindle depending on your wheel size and spindle type. You can seem them in this page of the instructions.
Old 12-02-2024, 09:09 PM   #35
SkinnyG
SkinnyG's Avatar
Re: Explorer 8.8
Oh. I did not see that those were heim joints.
It looks like the spacer is "ideal" according to the instructions, with removing the spacer only to fit smaller wheels. Fit the bigger wheels if you can.
Old 12-03-2024, 11:13 AM   #36
jweb
jweb's Avatar
Re: Explorer 8.8
I have some 15" wheels on while I work on the Suburban. Once I feel it's ready to drive I'll switch to the 22" transport wheels and add the spacers.
Old 01-15-2025, 01:57 PM   #37
jweb
jweb's Avatar
Re: Explorer 8.8
Well , I haven’t made much progress on the rear suspension. Had multiple issues with the GMSS trailing arm crossmember and some issues with the QA1 parts.
GMSS Crossmember - This really just doesn’t fit. It’s a 3 piece design, which should make it easier to install. I had 3 issues.
1: the main part of the crossmember was wider than my frame rails, so I had to spread them apart.
2: The side brackets were so wide they stuck out of the frame rails 1/2”. These had to be cut down especially with the already tight fitting center section.
3: The anti squat brackets don’t fit, they hit the floor brace. GMSS sent me new brackets, these only have 4 holes for adjustment and they’re spaced unevenly. They’ll work but I’m not impressed.
I wouldn’t recommend this for anyone looking to swap their trailing arm crossmember. Tinworks or Porterbilt are better options.
First photo shows brackets upside down, second shows the brace they hit, the brackets are about 1” too tall
On the QA1 kit I got the Coilover brackets included need to be installed right where I already have a bolt in C notch. I probably could have cut up the 2 and welded them together but I contacted QA1 and I was able to purchase their Cnotch brackets that have the coilover mounts built in. Another $300 but I think it’s a better solution.
Old 01-15-2025, 02:02 PM   #38
jweb
jweb's Avatar
Re: Explorer 8.8
Been working on the grill since I’m waiting on parts.
Made it much more complicated than I should have I cut all the mounts off the letters and welded a stiffener to the back of the letters, hoping to make it look more like it was floating. Unfortunately it was still too flimsy so I had to make new brackets for the ends.
Should have left the stock brackets alone like everyone else.
Still unsure if I’ll use this or stock.
Old 01-15-2025, 04:07 PM   #39
SkinnyG
SkinnyG's Avatar
Re: Explorer 8.8
What if you remove the rest of the mounts off the letters, and add a black mesh behind, so the letters look like they are "floating" on the mesh?
Old 01-15-2025, 05:15 PM   #40
jweb
jweb's Avatar
Re: Explorer 8.8
I might mock that up and see what it looks like. If I did that, I would cut out the center support also.
Old 01-15-2025, 09:15 PM   #41
SkinnyG
SkinnyG's Avatar
Re: Explorer 8.8
I was thinking remove the center, but keep the letter bar. It would be easier to mount and secure the letters.
Old 01-16-2025, 01:59 PM   #42
MikeN
MikeN's Avatar
Re: Explorer 8.8
Sorry for your complications, but the work sure looks great.
MikeN is offline   Reply With Quote
Old 01-20-2025, 07:49 PM   #43
jweb
jweb's Avatar
Re: Explorer 8.8
Got the QA1 rear suspension installed. Having their C notch kit makes it look much cleaner than if I had welded the coilover brackets to my old C notch. Also got the new anti squat brackets from GMSS and they fit good.
If I had to do it all over again I would have bought the full QA1 kit that included the C notch brackets and the adjustable trailing arms.
Having a mis match of parts isn’t great. The CPP tubular trailing arms, GMSS trailing arm crossmember and the QA1 coilovers will be fine but the wheels are a little too far forward in the opening. I’ll worry about that and the ride height after I’m done with everything else.
Also, plenty of space between the rear end housing and the panhard bar. I was a little concerned about the offset housing. Need to get the sway bar in but I don’t think that will be an issue either.
Old 01-21-2025, 10:21 AM   #44
SCOTI
SCOTI's Avatar
Re: Explorer 8.8
Why didn't you get the QA1 Adjustable T/A's?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-21-2025, 06:58 PM   #45
jweb
jweb's Avatar
Re: Explorer 8.8
1: I already had the CPP tubular arms
2: The price difference between the coilover kit I got is $1250 and the full kit is $2750. Initially I thought the only difference was the trailing arms, it also includes the C notch brackets I ended up buying.
I’ve got about $1800 into the rear set up I have and wasn’t sure it was worth the difference in cost.
I’m going to wait until I’m assembling for the final time, if the rear is still off center I’ll deal with it then.
Possibly get the QA1 arms, Tinworks adjustable arms or just move the trailing arm crossmember back slightly.
I need to get the grill finished and the rest of my parts blasted and ready for paint. I’m hoping to drop it off in March.
