Old 11-29-2024, 01:06 PM   #18
NolanAM22
Re: 1969 C10 Front Wheel Seal Not Flush
Originally Posted by pjmoreland View Post
I did a parametric search on the Timken website using the same shaft and outer diameter as the seal you used, and it came up with another seal that is .250" wide. It might be worth giving it a try.
Timken 4739
https://www.summitracing.com/parts/TMK-4739
https://engineering.timken.com/engin...l/seal-search/
Thanks. The Timken 4739 looks very similar to the 8871 that I pulled off, with the exception that the 8871 has a flange to mate against the hub top surface.
I'm not a seal expert, but does a seal need to be bedded against some type of surface or can it "free float" for lack of a better word? The 8871 is bedded against the top surface of the hub via its flange and is 0.260" thick. The 9015S is bedded against the top of the race surface via its bottom surface and is 0.505" thick. The race top surface to hub top surface is ~0.340", so the Timken 4739 would be "free floating" and not bedded against any type of surface. Only the friction of the side walls would be holding it in place. I wonder if that would make it more prone to being out of square with the shaft, not sure.
I appreciate you looking into it, PJ.
NolanAM22 is offline   Reply With Quote
