Old 12-14-2023, 01:24 PM   #26
Tip70
Tip70's Avatar
Re: 1970 Jiffy Mount Tire C10 build
Originally Posted by Scurry67 View Post
Looking good!
Thanks!
1970 C/10 LWB
build thread:
https://67-72chevytrucks.com/vboard/...d.php?t=847860
IG- Tip70
https://www.etsy.com/shop/Tip70Designs
Tip70 is offline   Reply With Quote
Old 12-18-2023, 02:32 PM   #27
Tip70
Tip70's Avatar
getting close to finishing up this side. I have a few holes to fill, that I was having trouble getting a good weld without blow out. I bought some more wire and went with a smaller size .025 down from the .030 I had on hand. Which on some test welds with the other side, is laying down smoother.
I put down some tape and paint to clean up the lines to make them straight. deciding still if id like to keep the welds or hide them. we will see
1970 C/10 LWB
build thread:
IG- Tip70
Old 12-18-2023, 03:56 PM   #28
loudchevy
loudchevy's Avatar
Good progress!
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 12-19-2023, 08:56 AM   #29
clay68c10
clay68c10's Avatar
Nice work, I like how you did your cuts.
You will have a much easier time with the thinner wire.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 12-19-2023, 01:06 PM   #30
Tip70
Tip70's Avatar
I did some more welding last night and you're right, its laying down a lot better
the cut lines I went off from was the Brothers truck video with David Welch. He walked through it in great detail
1970 C/10 LWB
build thread:
IG- Tip70
Old 12-19-2023, 01:06 PM   #31
Tip70
Tip70's Avatar
Originally Posted by loudchevy View Post
Good progress!
thanks!
1970 C/10 LWB
build thread:
IG- Tip70
Old 01-03-2024, 05:21 PM   #32
Tip70
Tip70's Avatar
update pics, getting closer to finishing up the bed. Then I will be able to get the truck back in the shop and start on the frame!
1970 C/10 LWB
build thread:
IG- Tip70
Old 02-07-2024, 09:46 AM   #33
raggedjim
raggedjim's Avatar
Great work, it will be like having a whole new truck when you are done.
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 02-07-2024, 03:42 PM   #34
Tip70
Tip70's Avatar
defiantly! after 20+ years, its fun breathing new life into the truck!
1970 C/10 LWB
build thread:
IG- Tip70
Old 02-15-2024, 06:54 PM   #35
Tip70
Tip70's Avatar
I finished up the box. The welds aren't perfect but I'm liking it. Now I'm waiting on some clear weather to swap out for the truck that's on the side of the house. Garage is too small for both. I just received my conversion kit from long shot fab, so I'm itching to get cutting
I've always kicked myself that I did not save my old tailgate for the embossed letters to graft into the one I have now. But for now some weathered painted letters will do under that rectangle piece of paper is my license plate
1970 C/10 LWB
build thread:
IG- Tip70
Old 02-20-2024, 01:16 PM   #36
Tip70
Tip70's Avatar
Got the truck in the garage, lets get to cuttin!
1970 C/10 LWB
build thread:
IG- Tip70
Old 02-20-2024, 03:06 PM   #37
loudchevy
loudchevy's Avatar
Good luck! The short bed looks great, nice job.
Scott
2003 Tahoe Stock
Old 02-20-2024, 05:49 PM   #38
Tip70
Tip70's Avatar
thank you!
1970 C/10 LWB
build thread:
IG- Tip70
Old 04-24-2024, 05:15 PM   #39
Tip70
Tip70's Avatar
Haven't been updating the progress lately, sorry for that. here are some pics of the Long Shot fab kit installed and frame cut. Also the rear cab mount moved back. Thought I had pics of the frame bolted back together, but I guess I never did
1970 C/10 LWB
build thread:
IG- Tip70
Old 04-24-2024, 05:23 PM   #40
Tip70
Tip70's Avatar
Here are some shots of the truck. Loving the look of the shortness also look at the extra room ive got in the shop!
All I have to do now is fix the gas line, brake line, and rerun the air lines and wiring with the bed back on, so I can move it over to my friend that will weld it up right! getting close!
1970 C/10 LWB
build thread:
IG- Tip70
Old 07-31-2024, 12:14 PM   #41
Tip70
Tip70's Avatar
Finally was able to get all the small things done (brake line, gas line, exhaust ect) to be able to get the bed back on the frame.
Awesome to be able to see it all together! now on to rerunning air lines and wiring.
1970 C/10 LWB
build thread:
IG- Tip70
Old 07-31-2024, 12:32 PM   #42
loudchevy
loudchevy's Avatar
Love it, nice job shortening the bed.
Scott
2003 Tahoe Stock
Old 07-31-2024, 12:37 PM   #43
Tip70
Tip70's Avatar
thanks! It was a fun challenge to undertake. glad I didnt destroy it, though the "keep it longbed" people might disagree
1970 C/10 LWB
build thread:
IG- Tip70
Old 09-25-2024, 02:15 PM   #44
Tip70
Tip70's Avatar
made these decals for the bed scars
1970 C/10 LWB
build thread:
IG- Tip70
Old 09-25-2024, 02:24 PM   #45
Tip70
Tip70's Avatar
working on finishing up the bed floor and air management setup. Im going to put in a raised bed floor to hide everything, plan on having a door in the center open up to show off the tank and compressors, so I took some time to make it look nice. coming along, slowly but surely.
1970 C/10 LWB
build thread:
IG- Tip70
Old 11-29-2024, 09:59 PM   #46
Tip70
Tip70's Avatar
This winter project, I will be redesigning the door panels. After sewing up my seat covers, I knew I needed to add the plaid to the panels to tie it all together.
I was working with the design but went with a bigger section as you can see in the last pic.
1970 C/10 LWB
build thread:
IG- Tip70
