Old 12-11-2024, 12:54 AM   #1
Kalums
Opinions on a phenolic spacer in AZ
Ok guys I've searched on the forum and a few others around the internet, there are a lot of conflicting opinions and very few actual facts I can find, "To phenolic spacer or not to phenolic spacer". I've got a 71 GMC K2500 with a 350/TH350, I've currently got an Edelbrock 1406 and square to spreadbore adapter to the original cast-iron manifold which is leaking from the front water jacket/passage. I'm planning on swapping to a Weiand 8004 aluminum manifold and a Holley 80555C carb. I live in Phoenix, AZ... Am I going to need a phenolic spacer? If I do... Do I use the wood/composite (it looks like brown plastic? With wood shavings inside *shrugs*) one that came with the Holley? Or? TIA
Kalums is offline   Reply With Quote
Old 12-11-2024, 01:13 AM   #2
geezer#99
geezer#99's Avatar
Re: Opinions on a phenolic spacer in AZ
With a Holley you don’t need a phenolic spacer.
The float bowls being fore and aft need a heat deflector instead.
One like this.
https://www.summitracing.com/parts/h...SABEgJCa_D_BwE
Old 12-11-2024, 01:25 AM   #3
Kalums
One like this.
Will that work on a spreadbore like the 80555C?
Edit: Apparently I need Holley part # 108-69....that appears to be out of production/ discontinued... So looks like I might be making one... *shrugs* "Necessity is the mother of invention..."
Old 12-11-2024, 01:30 AM   #4
jhe.1973
jhe.1973's Avatar
Thanks geezer for the tip and the link. I wasn't aware of a heat deflector as shown. Makes a bunch of sense!
Best wishes to ya’ll. Sincerely, Jim
"To invent you need a good imagination and a pile of junk" - Thomas Edison
"I've always wanted to get a job as a procrastinator - but, I keep putting off looking for one - I guess I'll never realize my life's dream - so sad." - Me
My C30 wrecker build/repair/update thread: https://67-72chevytrucks.com/vboard/...d.php?t=855904
jhe.1973 is offline   Reply With Quote
Old 12-11-2024, 01:42 AM   #5
jhe.1973
jhe.1973's Avatar
It looks to me that you would need this one that mentions specifically the quadrajet (speadbore) application:
https://www.summitracing.com/parts/o...0211?rrec=true
Old 12-11-2024, 01:46 AM   #6
Kalums
You Sir, Rock!! Thank you!
Old 12-11-2024, 10:51 AM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
Fel-Pro Carburetor Mounting Gasket - 60482
1/4 thick with a spacer to keep from over tightening it and deforming
Old 12-12-2024, 10:30 PM   #8
Rust_never_sleeps
Rust_never_sleeps's Avatar
My truck had one of these. Worked fine in NorCal, we got high 90's but only a few days into the 100's, so AZ might be different.
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 12-12-2024, 10:49 PM   #9
Kalums
I've already experienced a few times the 1406 Eddy boiling the fuel even with the 1/2" square to spread adapter 120 dgrs exterior temps does some crazy stuff to carbs...
Old 12-13-2024, 11:05 AM   #10
Dashman
Those aluminum spread bore to square bore adapters are heat sinks, they absorb heat. The same with the aluminum manifolds, but the benefit is that they atomize the fuel better. Try the 1/4" spread bore gasket with your manifold and carburetor choice, and see if that doesn't solve the issue. If not, I would ask Weiand what they recommend for Arizona temperatures.
Dashman is offline   Reply With Quote
Old 12-13-2024, 04:15 PM   #11
'68OrangeSunshine
'68OrangeSunshine's Avatar
I have a Weiand 8004/Offy Spreadbore-Squarebore adapter/3/4'' phenolic spacer/Carter AFB 9635S [=EDL-1405] on a 350 V8 in a '71 GMC Jimmy in Tucson. It works good, even in the summer here.
