Old 10-30-2024, 10:18 PM   #201
gottattooz
gottattooz's Avatar
Re: 1967 buick special wagon
With the front and rear of the wagon looking so aggressive, the sides between the tires look so skinny. So I flipped the bracket that mounts the side skirt, spaced it out with 1.5 x 3 inch rectangular steel spacers and pushed the skirts out 5 inches in total.
Josh
1967 Buick Special wagon
1968 Jeep Wagoneer
1958 Chevy Panel Truck
2017 Suzuki M109R
gottattooz is offline   Reply With Quote
Old 10-30-2024, 10:28 PM   #202
gottattooz
gottattooz's Avatar
With the bracket flipped and the 3 inch spacers, the skirts moved out about 5 inches. Now I have to figure out how to best fill the space between the body line at the bottom of the doors and the skirts.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 11-07-2024, 02:33 AM   #203
gottattooz
gottattooz's Avatar
Using cardboard templates to figure out the filler panels for the side skirts. I painted it white for better visual reference.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 11-07-2024, 02:40 AM   #204
3757chevy
3757chevy's Avatar
Nice.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 11-07-2024, 11:07 PM   #205
gottattooz
gottattooz's Avatar
I started working on making wedges for the bottoms of the doors.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 11-07-2024, 11:12 PM   #206
gottattooz
gottattooz's Avatar
I started mocking up the driver's side when my dad's friend walked into the shop and we were discussing the design. I told him it wouldn't work as a single piece, and mocked it up to show him. Turns out, I was wrong. It totally works as one piece. I'll just need to sweep the leading edges of the extensions back just a little. So, Version 2.0. They'll be one piece.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 11-16-2024, 06:29 PM   #207
gottattooz
gottattooz's Avatar
I bought a length of 16 gage sheet metal for the skirt filler panel
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 11-19-2024, 11:07 PM   #208
gottattooz
gottattooz's Avatar
The passenger rear tire keeps rubbing on a bolt head under acceleration. It's barely touching the raised letters on the sidewall, like the dot numbers and things like that. Well I got curious enough to remove the bolt to see what it held on. Apparently there are vibration dampeners on either side of the rear suspension cradle. Well the bolt heads snapped off, so I just cut the dampeners off with a sawzall, and now they're plenty of clearance.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 11-19-2024, 11:12 PM   #209
gottattooz
gottattooz's Avatar
I removed the front bumper and air dam. I cut out the center panels and made new ones that have a smoother transition to the chevelle bumper I used. There's still a lot of finish work to be done, but I think it'll look a lot better this way
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 11-24-2024, 01:31 AM   #210
gottattooz
gottattooz's Avatar
I separated the air dam and bumper. I painted the air dam white and cleaned the bumper with steel wool and some paint cleaner. I installed them on the wagon and took a few vantage point pictures to show the ground clearance and the general stance.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 11-24-2024, 09:02 PM   #211
gottattooz
gottattooz's Avatar
I'm putting the cargo windows back in, so I can road test longer distances. The driver's side fit snuggly in the pocket. I just held it in place with a few self tappers against the chrome trim. The trim has been bonded pretty securely to the glass.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 11-24-2024, 09:08 PM   #212
gottattooz
gottattooz's Avatar
I made a plywood panel to fit in the passenger cargo window pocket since it's a lot worse off and will need more repair work.
As I was putting the tail gate glass in, the bolts for the tracks broke off. So I drilled them out and installed riv-nuts.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 11-29-2024, 01:20 AM   #213
gottattooz
gottattooz's Avatar
First road trip successfully in the books. 750 miles round trip from Atlanta to Biloxi, ms and back. The only thing that broke was the left tail light fell off. Apparently the bolt holding it on vibrated loose and the light was dangling by the wiring. Since the bolt in question requires the tail gate to be opened and I wedged the back glass up and in place for the trip, I secured the light with some muffler strapping and some self tappers.
On the way down, I was running 83 mph, getting 18.5 mpg. On the way home, I set the cruise to 75 and got 20.6 mpg. Not too shabby, if i do say so myself
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 12-03-2024, 09:27 PM   #214
gottattooz
gottattooz's Avatar
As much as I like the srx tail lights, they just seemed a little too bulky and stuck out passed the rear bumper. I finally found a cadillac ats in the junk yard, so I grabbed the tail lights, harnesses and cut out the quarters for the mount buckets. These lenses are cracked, but I'm going to buy the clear lens tail lights with the integrated amber turn signals, so these are just for mock up. But the ats lights do not have reverse lights, so I have to either find lights that fill in the gap between the bumper or get a 65 el camino bumper with reverse lights. I'm keeping my eyes peeled for some late model pick up fog lights that mount on a slight angle in the front bumper to use a reverse lights.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 12-08-2024, 11:34 PM   #215
gottattooz
gottattooz's Avatar
I messed with the ats tail lights for a few hours before calling it "good enough" I filled in where the srx tail lights left holes in the quarter panels. If you look closely, you can see the passenger side light is leaning inboard at the top just a bit, but that's a close as I could get it. I should get my clear lens lights this week with integrated amber turn signals, as well as the fog lights I bought to use as reverse lights.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 12-08-2024, 11:43 PM   #216
gottattooz
gottattooz's Avatar
I cut out the rest of the original buick rear floor board, welded in some 1"x1" angle iron to set the desired floor height, and sealed off both ends of the floor where the wiring goes. When I'm finished with the rest of the floor, I'll seal where the wiring comes through with expanding foam or something similar. I used a 1.5"x1.5" angle iron section for the back support for the floor panel will go. I'm thinking I'll make small block off panels for the ends by the tail lights and hopefully make the rest of the floor panel in one piece.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 12-11-2024, 09:54 PM   #217
gottattooz
gottattooz's Avatar
I finished the cargo area floor panels. I drilled holes every inch and epoxy painted the bottom sides, plug welded the holes. Smoothed out the welds and epoxy painted the tops. I still have to seal the seams, but it's pretty much done
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 12-14-2024, 12:41 AM   #218
gottattooz
gottattooz's Avatar
I bought some clear lens tail lights, thinking they'll look a lot cooler with the gun metal gray I plan on painting the wagon. They were supposed to have amber leds in them for turn signals, as pictured in the ad, but they're standard tail lights with all red legs.
So, now I need to figure out turn signals, and I bought a pair of strip lights with clear lenses with amber led lights. There is a slight curve on the tail light where I want to mount them, so I clamped them to a section of b-pillar from a previous body swap and used my shop heater to coerce the light into shape without melting the plastic or burning up the wiring.
The red tail lights are just test dummy lights I'm using to figure out the quarter fender sheet metal and placement of the reverse lights, so imagine the clear lens turn signal strip mounted to the clear lens tail lights. It's not what I wanted initially, but I'm still figuring things out.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
