12-02-2024, 11:22 PM | #51 |
Re: 1942 Chevrolet Flatbed that ate My Brain
I am trying to figure out the fuel lines. The fuel lines on the tank are the type that have a rubber seal. The TBI has the same. I will look at fuel line and adapters online and see if there is something that will work. Any ideas where to look?
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344 1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494 R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438 1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250 |
12-03-2024, 10:46 AM | #52 |
I'd start here, https://www.russellperformance.com/s...b39jR5jiV3Mav8
12-12-2024, 11:44 PM | #53 |
Thank you for the link.
12-12-2024, 11:56 PM | #54 |
Tank done and lines
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344 1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494 R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438 1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250 Last edited by Rickysnickers; 12-13-2024 at 10:19 AM. |
12-12-2024, 11:58 PM | #55 |
I don't know how I missed this Thread.
Great build. I am Subbed now . I like the Grill the most on these Trucks.
12-13-2024, 12:02 AM | #56 |
I started to work on the shifter. It is an American Shifter from the Hoffman Group. I now everyone says they are junk but I put it together and called tech support and it is working out so far
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344 1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494 R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438 1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250 Last edited by Rickysnickers; 12-13-2024 at 10:20 AM. |
12-13-2024, 12:10 AM | #57 |
Thank you. I am really going to try to keep going on this and finish it to at least a driving point.
12-15-2024, 12:11 PM | #58 |
Fuel and return line are done. Not sure what to do with the vent lines. Started cleaning the transmission. I had a bunch of different products and Purple Power seemed to work well. I will post a pic when clean. I installed an energy transmission mount. Now the engine and trans are locked in. I really need to mount the cab in its finished location, so I started trying to figure that out. When this body was on this frame before I only had the radiator locked in. This next week I will measure the distance of the fender holes to the top of the running board. That should give me the correct cab height. I dont remember if the top of the radiator support is level with the cab at the hood mounting locations. I also dont remember what the space is between the cab rocker and the top of the running board. I will post more pics
12-15-2024, 12:39 PM | #59 |
You have been Busy.
They make some prety good One way vent valves. Here is a Link below for one, They make some fancy ones also. Link: https://www.amazon.com/dp/B0C4QW91QB
12-15-2024, 05:11 PM | #60 |
Thanks for the link. Thanks for following
