Old 12-19-2024, 04:21 PM   #1
chris989
mysterious death wobble
Hello all,
1989 v2500, 2 inch lift, 37 falkens
A few months ago i experienced my first ever wobble in this truck. Other than a tire rotation and new steering box nothing has changed. It wasn't horrific but definitely a shock since for more than a decade and many many miles it has never done it.
I've been under the truck all morning and nothing looks a miss.. all tight, no movement in and joint, bushing or bearing. (that i can detect)
If you ever had this and figured out the culprit, please share.
Thank you,
Chris
chris989 is offline   Reply With Quote
Old 12-19-2024, 11:00 PM   #2
GM72K10
Next!
GM72K10's Avatar
Re: mysterious death wobble
My death wobble was caused by a partially restricted front brake hose. Put on new front brake hoses and problem went away! Took quite a while to figure that out.
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 12-20-2024, 01:37 AM   #3
dagnabbitt
dagnabbitt's Avatar
It's scary. On my truck it was the tires, severe cupping. Always happened when tires were cold at 45 mph. With a lift and 37s I would take a look.
Its intermittent because the tires are essentially out of round, and the death wobble only occurs when they all hit the same flat spot at the same time.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 12-20-2024, 09:44 AM   #4
raggedjim
raggedjim's Avatar
I've had this on Chevrolet trucks before. On mine it felt more like a hard shuddering.
Had this on my Jeep, new tires cured it.
raggedjim is offline   Reply With Quote
Old 12-20-2024, 11:22 AM   #5
Willie Makeit
Willie Makeit's Avatar
Worn ball joints have been known to cause this as well.
Willie Makeit is online now   Reply With Quote
Old 12-20-2024, 12:25 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
do you have the proper or a new steering damper on it ( the shock crossways on the front end) i had a truck that that piece was shot and caused a wobble after the sloppy steering box was replaced
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-20-2024, 12:28 PM   #7
Stepside Jim
Mine was ball joints...
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132
Stepside Jim is offline   Reply With Quote
Old 12-20-2024, 05:10 PM   #8
Dead Parrot
Happened after tire rotation? Suspect bad or out of balance front tires. Especially if it was a front to back swap.
On my 84 K30, replacing the bushings between the axle and steering fixed it.
Dead Parrot is offline   Reply With Quote
Old 12-20-2024, 08:31 PM   #9
57taskforce
All about them K’s
57taskforce's Avatar
I assume you are talking about the king pin bushing on the Dana 60? The 10 bolt in his 3/4 ton won’t have those. I’d look into the tires more as well. I’ve even had a late model 3/4 ton IFS GMC that got death wobble because the tires were shot. That’s not supposed to be able to happen on IFS stuff. If it came from out of the blue I’d start with the things most recently changed first. When you add the bigger tires any issues with them just get amplified compared to stock size tires. Toe will cause it too if not set right, with 37’s I’d be shooting for closer to 1/4 toe in if it was me.
Tyler
57taskforce is online now   Reply With Quote
Old 12-20-2024, 09:20 PM   #10
cadillac_al
2" isn't much lift to cause a problem. I have had my K20 for 30 years and had the 2" lift and 35's for 20 years. The only time I had death wobble is when I had too much mud in the wheels. With clean wheels it will roll nice and smooth at 70-80 mph. On my Jeep Grand Cherokee the only time I had death wobble was with old flat spot tires. I always blame the tires first
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 12-21-2024, 03:24 PM   #11
chris989
Thanks for all the replies,
I spent a few hours under the truck the other day and everything looks tight and right.
The tires have 70% tread left and show no signs of uneven wear. I spoke to Laura's steering gear company wondering if possibly the tire was giving a negative feedback through the steering gear via the torsion bar and they'd never heard of that.
I had a steering gear with a 160 torsion bar and the tires would definitely feedback through the gearbox giving it a odd sensation.
This morning it happened again going maybe 20 miles an hour in a neighborhood after hitting a bump. I guess I'm going to put it back in the shop and just pull everything apart read grease reinspect.
Old 12-21-2024, 04:15 PM   #12
Getter-Done
Getter-Done's Avatar
Have you checked for cracks around the steering box?
84 Chevy K-20
Old 12-21-2024, 08:36 PM   #13
Dead Parrot
Originally Posted by 57taskforce View Post
I assume you are talking about the king pin bushing on the Dana 60? The 10 bolt in his 3/4 ton won’t have those. ....
Yes. Couldn't remember what they were called when I responded. Replaced them several years ago.
But his start after a bump symptoms are very similar to what mine was doing. If there is anything that serves a similar function on his, might start there.
Worn shocks? Frame good around the steering box?
Old 12-22-2024, 05:07 AM   #14
67swb72klb
67swb72klb's Avatar
I would be looking at the toe too if all your parts check out good..
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 12-22-2024, 10:58 AM   #15
Dashman
Active Member
I had it happen on my '81K20 after I had replaced EVERYTHING. Not like I was chasing the issue, everything was worn out. Axle U-joints, ball joints, steering gear box, steering rag joint, tie rod links, steering stabilizer, brake lines, leaf spring bushings (as part of a lift kit), and tires. The two last things that stopped it were the drag link ends, and shocks. I believe that shocks play a major role in dampening the vertical wheel movement that would prevent the issue. It's doing it on my current '72K10 project because I don't have shocks on it.
Dashman is offline   Reply With Quote
Old 12-23-2024, 10:13 PM   #16
chris989
Update,,
Had the tires balanced and rotated today and pulling out of the parking lot i got the wobble at ~15 mph..
I am under the truck now and everything is tight.. THe tie rods ends do rotate easier than when new.
I will pull the shocks next,,, I run quad nitrogens.
I will update when i figure it out..
Chris
Old 12-23-2024, 10:30 PM   #17
cadillac_al
Did you check for a crack by the steering box? I have never had one but people say it is common. I would think if you could have somebody move the steering wheel side to side while you look at it it should not be moving.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
Old 12-23-2024, 11:00 PM   #18
chris989
I checked,, all good. THe truck is on stands with tires off. with the steering locked,, there is zero movement in the hubs, links, etc. The is a little movement in the lash of the steering gear..
The shocks show no sign of fatigue or leaking... I will pull them tomorrow anyway..
Chris
Old 12-23-2024, 11:53 PM   #19
KQQL IT
At the body shop.
KQQL IT's Avatar
Have someone rock the wheel, while you're under it.
Look for something loose.
Box 1st
KQQL IT is online now   Reply With Quote
Old 12-24-2024, 01:38 AM   #20
3drburb
What is the condition of the rag joint?
3drburb is offline   Reply With Quote
Old 12-24-2024, 02:21 AM   #21
3drburb
Looking at your first post, we should says bad steering box or tires, then after another rotation it seemed to have gotten worse?
Tires unbalanced, a flat spot on a tire.
Do you have another set of wheels and tires to put on to test?
Old 12-24-2024, 12:54 PM   #22
chris989
I found something,
installing new pads today and noticed the thin metal plate behind the brake pad has slid haveway out. It is not touching the rotor but maybe the pad being off plane the thickness of the plate is causing it to grab????
I will upload a picture when i get to the shop
Old 12-25-2024, 02:19 PM   #23
farmall
farmall's Avatar
Larger, crappy, unbalanced tires and wider wheels expose all the ailments of your 35 year old axle.
Find and buy a used axle. Put it on saw horses and replace everything from lock out to lock out. Bearings, ball joints, seals, rotors, calipers, hoses, tie rod ends, drag link and U-bolts.
Do it at your own leisure. It does not cost a fortune. Difficulty is low.
I took my knuckles to a friends shop to get the ball joints pressed out.
Clean and paint. Sell your old one and you have a rock solid investment in your rig.
How about a Detroit Trutrac?
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 12-25-2024, 02:40 PM   #24
chris989
The axle is all new,, the truck has ~500k miles but the axle is new 456 gear, eaton posi, seals, bearing, all moog joints etc.
I have a truetrac in my 67 camaro and love it, It has never not works flawless on a launch and it is smooth as silk on the road. I am installing trutracs in my 78 ford.
Old 12-25-2024, 02:43 PM   #25
chris989
this is the brake that lost it thin plate. somehow slipped downward?
