Old 12-16-2024, 05:49 PM   #1
howzzzit
howzzzit's Avatar
Tip from ACC carpets
Good morning! when you go to install our product, I would let it sit in the vehicle with heat or steam to let the material relax. Make sure to actually put it in the vehicle and not just on the ground, otherwise it’s not going to have anything to form to and it could go flat.
Thanks,
Cathy Davidson
Customer Service
Auto Custom Carpets, Inc
howzzzit is offline   Reply With Quote
Old 12-16-2024, 06:14 PM   #2
custom10nut
custom10nut's Avatar
Re: Tip from ACC carpets
Good tip, makes perfect sense.
custom10nut is offline   Reply With Quote
Old 12-17-2024, 01:01 PM   #3
72SB
and use a soldering iron for the bolt holes you need to make
72SB is offline   Reply With Quote
Old 12-17-2024, 04:46 PM   #4
sfont66
sfont66's Avatar
Another way to help the wrinkles relax is to unfold the carpet and weather permitting, let the carpet sit in the sun a couple hours and then install it promptly while still warm
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB.
Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project
sfont66 is offline   Reply With Quote
Old 12-17-2024, 05:09 PM   #5
howzzzit
howzzzit's Avatar
Can you feel through mass backing where to poke it? Come from underneath?
Old 12-17-2024, 05:10 PM   #6
howzzzit
howzzzit's Avatar
That was my original thought, but see post 1.
Old 12-19-2024, 10:58 AM   #7
Extended Power
Extended Power's Avatar
Just watched a guy on YouTube that used a nail to poke through the carpet once you locate the hole. (This helps keep the carpet in place, and where the hole has to go.)
Then heat up a 14mm socket that is on the end of a long extension and heat the socket with a torch. Once red hot, hold the socket on the carpet where the nail is and make the hole you require for seat belt bolts or brackets.
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old Yesterday, 11:19 AM   #8
72c20customcamper
72c20customcamper's Avatar
A pick or awl from underneath works well . I let the carpet relax in the truck for a few days and before I actually started any cutting I placed a ceramic heater in the truck for a few hours as I was doing it in April and it wasn’t all that warm
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old Yesterday, 03:35 PM   #9
jayoldschool
Moderator
Easiest way: put the bolts back in the bare floor. Easy to find where to cut/burn. Don't drill (advice from my 17 year old self after putting new loop in my 71 Pontiac.. before the internet told me what would happen).
jayoldschool is offline   Reply With Quote
Old Yesterday, 07:28 PM   #10
MikeB
MikeB's Avatar
I've used a hollow punch for making holes in carpet. First poke a hole through with an awl, then smack the punch a few times with a hammer, using a 2x4 as backing (to save the floor and the punch).
You'll want to use a punch larger that the 5/16" bolts so they will start easily and not try to grab the carpet strands. Sorry for the image size, but I can't see how to make it any smaller.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
