12-19-2024, 04:21 PM | #1 |
mysterious death wobble
Hello all,
1989 v2500, 2 inch lift, 37 falkens A few months ago i experienced my first ever wobble in this truck. Other than a tire rotation and new steering box nothing has changed. It wasn't horrific but definitely a shock since for more than a decade and many many miles it has never done it. I've been under the truck all morning and nothing looks a miss.. all tight, no movement in and joint, bushing or bearing. (that i can detect) If you ever had this and figured out the culprit, please share. Thank you, Chris |
12-19-2024, 11:00 PM | #2 |
Next!
Re: mysterious death wobble
My death wobble was caused by a partially restricted front brake hose. Put on new front brake hoses and problem went away! Took quite a while to figure that out.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
12-20-2024, 01:37 AM | #3 |
It's scary. On my truck it was the tires, severe cupping. Always happened when tires were cold at 45 mph. With a lift and 37s I would take a look.
Its intermittent because the tires are essentially out of round, and the death wobble only occurs when they all hit the same flat spot at the same time.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
12-20-2024, 09:44 AM | #4 | ||
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
12-20-2024, 11:22 AM | #5 |
Worn ball joints have been known to cause this as well.
12-20-2024, 12:25 PM | #6 |
Robert Olson Transport
do you have the proper or a new steering damper on it ( the shock crossways on the front end) i had a truck that that piece was shot and caused a wobble after the sloppy steering box was replaced
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
12-20-2024, 12:28 PM | #7 |
Mine was ball joints...
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132 |
12-20-2024, 05:10 PM | #8 |
Happened after tire rotation? Suspect bad or out of balance front tires. Especially if it was a front to back swap.
On my 84 K30, replacing the bushings between the axle and steering fixed it. |
12-20-2024, 08:31 PM | #9 |
All about them K’s
I assume you are talking about the king pin bushing on the Dana 60? The 10 bolt in his 3/4 ton won’t have those. I’d look into the tires more as well. I’ve even had a late model 3/4 ton IFS GMC that got death wobble because the tires were shot. That’s not supposed to be able to happen on IFS stuff. If it came from out of the blue I’d start with the things most recently changed first. When you add the bigger tires any issues with them just get amplified compared to stock size tires. Toe will cause it too if not set right, with 37’s I’d be shooting for closer to 1/4 toe in if it was me.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
12-20-2024, 09:20 PM | #10 |
2" isn't much lift to cause a problem. I have had my K20 for 30 years and had the 2" lift and 35's for 20 years. The only time I had death wobble is when I had too much mud in the wheels. With clean wheels it will roll nice and smooth at 70-80 mph. On my Jeep Grand Cherokee the only time I had death wobble was with old flat spot tires. I always blame the tires first
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
12-21-2024, 03:24 PM | #11 |
Thanks for all the replies,
I spent a few hours under the truck the other day and everything looks tight and right. The tires have 70% tread left and show no signs of uneven wear. I spoke to Laura's steering gear company wondering if possibly the tire was giving a negative feedback through the steering gear via the torsion bar and they'd never heard of that. I had a steering gear with a 160 torsion bar and the tires would definitely feedback through the gearbox giving it a odd sensation. This morning it happened again going maybe 20 miles an hour in a neighborhood after hitting a bump. I guess I'm going to put it back in the shop and just pull everything apart read grease reinspect. |
12-21-2024, 04:15 PM | #12 |
Have you checked for cracks around the steering box?
12-21-2024, 08:36 PM | #13 | |
But his start after a bump symptoms are very similar to what mine was doing. If there is anything that serves a similar function on his, might start there. Worn shocks? Frame good around the steering box? |
12-22-2024, 05:07 AM | #14 |
I would be looking at the toe too if all your parts check out good..
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
12-22-2024, 10:58 AM | #15 |
Active Member
I had it happen on my '81K20 after I had replaced EVERYTHING. Not like I was chasing the issue, everything was worn out. Axle U-joints, ball joints, steering gear box, steering rag joint, tie rod links, steering stabilizer, brake lines, leaf spring bushings (as part of a lift kit), and tires. The two last things that stopped it were the drag link ends, and shocks. I believe that shocks play a major role in dampening the vertical wheel movement that would prevent the issue. It's doing it on my current '72K10 project because I don't have shocks on it.
Yesterday, 10:13 PM | #16 |
Update,,
Had the tires balanced and rotated today and pulling out of the parking lot i got the wobble at ~15 mph.. I am under the truck now and everything is tight.. THe tie rods ends do rotate easier than when new. I will pull the shocks next,,, I run quad nitrogens. I will update when i figure it out.. Chris |
Yesterday, 10:30 PM | #17 |
Did you check for a crack by the steering box? I have never had one but people say it is common. I would think if you could have somebody move the steering wheel side to side while you look at it it should not be moving.
Yesterday, 11:00 PM | #18 | |
The shocks show no sign of fatigue or leaking... I will pull them tomorrow anyway.. Chris |
Yesterday, 11:53 PM | #19 |
At the body shop.
Have someone rock the wheel, while you're under it.
Look for something loose. Box 1st
" That didnt make it any newer " " Dont antique the equipment " |
Today, 01:38 AM | #20 |
What is the condition of the rag joint?
Today, 02:21 AM | #21 |
Looking at your first post, we should says bad steering box or tires, then after another rotation it seemed to have gotten worse?
Tires unbalanced, a flat spot on a tire. Do you have another set of wheels and tires to put on to test? |
Today, 12:54 PM | #22 |
I found something,
installing new pads today and noticed the thin metal plate behind the brake pad has slid haveway out. It is not touching the rotor but maybe the pad being off plane the thickness of the plate is causing it to grab???? I will upload a picture when i get to the shop |
