Old 12-25-2024, 02:42 PM   #1
a Good Man
a Good Man's Avatar
Parking Brake Clearance w/ kick panel speakers
Hi All
I Have a Problem With Parking Brake Clearance w/ kick panel speakers . Are there any solutions and ways to solve this problem?
MY Facebook
( saad_alhajri ) on Instagram
a Good Man is offline   Reply With Quote
Old 12-25-2024, 02:59 PM   #2
907burb
Re: Parking Brake Clearance w/ kick panel speakers
You could install the hand brake from a 67-68 truck.
907burb is offline   Reply With Quote
Old 12-25-2024, 03:10 PM   #3
1970cstblazer
1970cstblazer's Avatar
You might be able to bend the parking brake pedal to clear the speaker housing.
Old 12-25-2024, 03:10 PM   #4
a Good Man
a Good Man's Avatar
I don't think this is a good solution. I'm thinking about this bend.
MY Facebook
Old 12-25-2024, 03:22 PM   #5
dmjlambert
dmjlambert's Avatar
That looks interesting. Could you show more pictures and from different angles?
Old 12-25-2024, 03:22 PM   #6
1970cstblazer
Thumbs up Re: Parking Brake Clearance w/ kick panel speakers
That looks good.
Old 12-25-2024, 03:37 PM   #7
a Good Man
a Good Man's Avatar
Definitely
MY Facebook
Old 12-25-2024, 04:45 PM   #8
dmjlambert
dmjlambert's Avatar
I think the bend you are thinking about would work as a solution. It will be interesting to see pictures of the completed bend/weld installed. You may need to also move the low/high beam stomp switch.
Old 12-25-2024, 10:28 PM   #9
custom10nut
custom10nut's Avatar
I considered putting the Kick Panel speakers in my truck, until I came to the same realization, the Park brake pedal won’t clear it.
I can’t remember if the Dimmer switch was going to be an issue also.
Reconfiguring the pedal lever would put the pedal four inches to the right, and look kinda awkward.
Leverage and strength of the lever would also come into play.
As someone said, putting a pull lever from a 67/68 would work for you with no issues.
custom10nut is offline   Reply With Quote
Old 12-26-2024, 08:37 AM   #10
I ended up doing this. I cut the emergency break pedal and pad. I used black RTV on the pad to hold it in place. I shifted the dimmer switch up and out a hair to have access to it. I have size 14 feet and pretty long legs so this gave me room to maneuver my body parts around well.
Your speakers are much deeper than mine so this may not work as well. I like you idea, but if your truck is manual it may make it awkard for using clucth or at least very tight on foot room. You will also probably need to shift the dimmer switch out more either way
Old 12-26-2024, 09:47 AM   #11
a Good Man
a Good Man's Avatar
I really appreciate your nice responses and all the solutions. I think bending is the best solution.
MY Facebook
Old 12-26-2024, 02:20 PM   #12
BIG ORANGE
BIG ORANGE's Avatar
Who sells the best abs kick panel for speakers? I see mixed or bad reviews online on most I've looked at. Where are yall buying yours?
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 12-26-2024, 02:23 PM   #13
70STOVEBOLT
70STOVEBOLT's Avatar
I have them in my truck and they clear just fine. I would venture a guess that it depends on the brand of speakers. The ones in the OP's pics look like they have thick grille on them. Mine are Kicker brand. I can get a pic after work if anyone wants to see, just post and let me know.
Edit: I looked at mine again and I have to slightly push the pedal to the right to clear them. If pushed straight down it would just catch the grille on the speaker. IDK what brand kick panels I have, my wife bought them for me for Christmas several years ago. Seems like they were Custom Autosound though.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 12-26-2024, 03:12 PM   #14
a Good Man
a Good Man's Avatar
I follow this account on Instagram. Their work is great. They seem professional. I haven't dealt with them but you can contact them.
MY Facebook
Old 12-26-2024, 05:46 PM   #15
HalfBrit
Always wondered about the parking brake interference. There are plenty of modern, high quality, shallow mount speakers available today. I wonder if any company has a newer kick panel design to take advantage of this?
HalfBrit is online now   Reply With Quote
Old 01-01-2025, 02:20 PM   #16
a Good Man
a Good Man's Avatar
I will work on it soon and let you know the results.
MY Facebook
Old 01-01-2025, 05:27 PM   #17
Rust_never_sleeps
Rust_never_sleeps's Avatar
Pondering the same thing, That enclosure is so deep it's kinda silly, and bending the e brake that far seems like it'd be awful close to the brake pedal.
Maybe swap in a manual trans pedal to maintain more separation if you end up using that bend?
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
