08-27-2004, 06:13 PM | #1 | |
Bloo
parts for sale
theres too much out there to list everything, so heres a couple prices on big main parts.
gauges- $5-20 depending on which gauge pulleys- $15 each headlight bezels-- 69-72 $20 67/8 $25 offer me a price, these prices are just estimates on market value so they may be out of line the rest of these parts in the pics make an offer or ask and i'll price it ill take more pics of any parts even if you dont see it, ask anyway, i may have it! EDIT: MORE PICS ADDED HERE!! (click here)
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
08-27-2004, 06:15 PM | #2 |
Bloo
ab
08-27-2004, 06:16 PM | #3 |
Bloo
cd
08-27-2004, 06:26 PM | #4 |
Bloo
ef
08-27-2004, 06:29 PM | #5 |
Bloo
gh
08-27-2004, 07:05 PM | #6 |
do u have any tach guages just the guage ??? and also do u have any 67-72 Crusise control stuff??? im also looking for a TH400 Slip yoke the peice of the driveshaft that goes into the tail shaft of the tranny ???
08-27-2004, 07:45 PM | #7 |
How much you want for one of your quadrajets....I think I saw one (4 barrell with with a divorced choke....
Trying to fix up an ol' q'jet for a buddy of mine and I am looking for some parts....throttle shaft and idle mixture pins. Let me know... |
08-27-2004, 08:41 PM | #8 | |
Bloo
robo-bot:
no tachs, no cruise, but i may possibly have the yoke you need. im not real sure what the yokes i have are for, but what spline is your output shaft? elenhoff- pic 4 in the first set (the original post) there are 2 quadrajets, one of them says "made by carter for GMC" and one is just a rochester, the carter i would take $20 for or the rochester $15. if youd rather just buy parts i will also sell just parts
08-27-2004, 08:42 PM | #9 |
ok its a Th400 so its a 32 spline
but ill double check, i checked and yes it is 32 spline Last edited by Robo_bot; 08-27-2004 at 08:55 PM. |
08-27-2004, 08:59 PM | #10 |
User #12137
did u see sum model trucks in there ? if any of them are 67-72 i want them how much and shiping to 37664 and do you have any 67-68 outer grill trim ?(i dont want the painted ones)anyway have a great day ,tnblazerk5
ps man you got sum stuff there dont ya |
08-27-2004, 09:07 PM | #11 |
do you have a good 69-72 radiator core support
04 GMC Sierra RCSS 70 CST LWB 04 HD Sportster 1200 Custom |
08-27-2004, 10:06 PM | #12 |
I need a good temp gage. got one? how much? to 37096
08-27-2004, 11:31 PM | #13 |
Bloo
robo-bot: thanks, ill check tomarow and see if i have any with that spline count
tnblazerk5:no grill trim, no models right now, sorry i couldnt help! (theres not TOO much there is it? lol) 73 stepside: i have an almost perfect 68 GMC radiator support, im not sure if it can be made to work though? (maybe remove inner headlamp buckets?), afraid i dont have any 69-72 ones right now though (the GMC one can partially be seen in the 4th set, 5th pic) zooza: i've got alot of temp gauges, i would take $10 for one plus shipping, which judging by weight and your location shouldnt be much but i'll pm you a quote tomarow |
08-27-2004, 11:36 PM | #14 |
Not a bad nut after all..
I need an upper alternator bracket that looks like the attached picture. I believe it is '72 only. It can be indentified by the 12" dimension and the longer adjustment slot.
Thanks in advance! |
08-28-2004, 11:44 AM | #15 |
Bloo
badpeanut-- no alt brackets, sorry!
08-28-2004, 01:05 PM | #16 |
User #12137
lol n.p but i did see sum model trucks in there didnt i ? if so take sum pics of those bad boys for us to look at ! why did i know those wasnt for sale
08-28-2004, 02:26 PM | #17 |
i have an alternator bracket like that but dont know if it is 12" or not....what are all the carbs? do any of them function correctly?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
08-28-2004, 02:28 PM | #18 |
in ur 7th pic up there is a header collector? is there a set and what do they fit and how much?
08-28-2004, 02:47 PM | #19 |
67ChevyC10Stepside, the alternator bracket is easily identified by the longer slot on the '72 style I need. I have a picture of the '67-'71 style if it would be helpful, also. Could you check? Maybe we could work out a deal on that headlight bezel you need.
08-28-2004, 03:13 PM | #20 |
Bloo
tnblazer-- ill take some pics of all my models when i get a chance and send ya, i have alot. kind of a side hobby (they're cheaper then the full size ones!)
67chevy- the carbs are: 2 carter AFB, 2 carter unknown (pic 4, far right), 2 quadrajet, 2 ford two barrel ( one holley, one fomoco), a rebuilt rochester 2 barrel, 2 GM 2 jets, and an edelbrock 600-650 (not sure which). one of the GM 2 jets was running but needs rebuild, the rochester 2 bbl was good when i got it but it's been sitting, a rebuild has been started on: one AFB, the holley, one gm 2 jet, and the edelbrock. i have everythign to finish the holley except one gasket, and the AFB and edelbrock both need gaskets to be finished. i do have a set of headers, they will work on 2wd and 4x4 sbc manual or auto. (4x4 takes z-bar mods). i have 3 headers to make a set, this is because one right side header has a broken collector, and another has the tubes beat almost flat. the collector needs to be cut off the flat tube one and welded to the other. i was going to do this and use them on my truck, but if you want to buy them ill take $70 for all 3. for $85 i can include another good left header. |
08-28-2004, 03:21 PM | #21 |
have u checked to see if u have a 32 spline slip yoke yet ???
08-28-2004, 10:34 PM | #22 |
Bloo
i checked in the building, werent any in there but i have a couple more in the toolbox on my 4x4. i'll check it tomarow when i go to work on the barn it's in
08-29-2004, 03:57 PM | #23 | |
Bloo
only one was still in the toolbox, it was a large slip/cap yoke with 16 splines (ex- one on front 4x4 driveshaft) and the other one i have is a small 16 spline like for a 3 speed
08-29-2004, 05:09 PM | #24 |
ok no worries thanx though
Nick |
08-30-2004, 02:04 PM | #25 |
Nothing clever
2 part question:
1. How much for a complete gauge cluster 2. and if that is to much how much for a speedo and a cable for a T350? shipping is to 90028. thanks
Got "the Midas Touch!" |
