Old 12-27-2024, 07:49 PM   #1
Old school57
Wheel studs
Does anyone know where I can get longer wheel studs for 72 3/4 ton 4x4 I need longer ones because the wheel I have lugs counter sink into the wheel .stock studs are too short and are flush with wheel.i need to have studs to stick out 5 or so threads
Old school57 is offline   Reply With Quote
Old 12-27-2024, 08:36 PM   #2
72c20customcamper
72c20customcamper's Avatar
Re: Wheel studs
I’ve used these guys before . Should have what you need
https://lugnutguys.com/
Edit: Sorry looks like they only sell lug nuts
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 12-27-2024, 08:53 PM   #3
TxGary
TxGary's Avatar
Re: Wheel studs
lugnut4x4.com
71 C-10 SWB
1969 C-30 Custom Camper Motorhome Restoration in progress.
2020 Chevy 2500 Crew 4x4 LTZ Diesel
2024 Chevy Tahoe Z71 4X4
2015 Diamond C 22' HD car hauler
Bowie, Texas 76230
TxGary is offline   Reply With Quote
Old 12-27-2024, 10:08 PM   #4
kwmech
Re: Wheel studs
610-227 dorman stock is 610-180
Old 12-27-2024, 10:51 PM   #5
Rust_never_sleeps
Rust_never_sleeps's Avatar
Re: Wheel studs
Yes they do still have studs(plus wheel bolts, spacers, centering rings....):
https://lugnutguys.com/pages/search-...tud-conversion
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is online now   Reply With Quote
Old 12-28-2024, 01:21 AM   #6
franken
Re: Wheel studs
https://www.google.com/search?q=lug+studs+nearby
I'd probably be looking for the correct lug nuts for the wheels.
Old 12-28-2024, 01:55 AM   #7
Richard
Re: Wheel studs
Possibly (probably) what franken said. The lug holes look pretty large and not sure if I see a taper for the nut. Sure you don't need a mag wheel lug nut that sleeves into the wheel? Like this https://lugnutguys.com/collections/l...nk-zinc-washer Not sure the exact ones you would need without more info.
Richard
Old 12-28-2024, 01:28 PM   #8
Old school57
Re: Wheel studs
I have the correct lug nuts .problem is if the studs aren’t 100% straight they won’t go on .stock studs are flush with rim I need a studs that will stick beyond the rim so I can get the studs started.
Old 12-28-2024, 01:38 PM   #9
Old school57
Re: Wheel studs
thanks I’ll check them out.
Old 12-28-2024, 01:41 PM   #10
Old school57
Re: Wheel studs
Thanks I’ll check them out I can’t afford to get the wrong studs @ 20$ a pop.
Old 12-28-2024, 01:47 PM   #11
Old school57
Re: Wheel studs
No taper on the wheel although nuts have a taper to them.
Old 12-28-2024, 01:52 PM   #12
Old school57
Re: Wheel studs
No taper on the rim if studs where a1/4 to 3/8 longer the taper on the nut would Guide the nut into the wheel .
Old 12-28-2024, 04:52 PM   #13
72c20customcamper
Re: Wheel studs
Just reread your post about the nuts you have. You should be able to get longer studs at NAPA or even Autozone .
Just don’t go too long or the cap could bottom out before the wheel is correctly torqued.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 12-28-2024, 05:09 PM   #14
Old school57
Re: Wheel studs
Yep that’s what I have they are a tight fit with a 9/16 stud .right now I’m cleaning up the studs and sanding the polish off the rim of wheel.I want to change out the studs because the truck has been in a house fire so might as well put a little longer.
Old 12-28-2024, 05:29 PM   #15
Richard
Re: Wheel studs
Okay, understand why you want the longer studs now. But, looking at the lug nuts you have- would think the wheel should have a taper at the face of holes. Your lug nuts have a taper under the hex where they seat on the wheel. Unlike the type I linked to.
Richard
Old 12-28-2024, 07:55 PM   #16
Old school57
Re: Wheel studs
They came with washers.
Old 12-28-2024, 11:53 PM   #17
franken
Re: Wheel studs
Those lug nuts look very wrong to me.
Old 12-29-2024, 11:40 AM   #18
Old school57
Re: Wheel studs
Why is that I have no problem replacing them.
Old 12-29-2024, 02:57 PM   #19
Rust_never_sleeps
Re: Wheel studs
Interesting. I thought they were all tapered to locate/center themselves in the hole
