Old 08-03-2007, 05:42 PM   #1
tractorsx
Need pics. of transfer case mounts and bushings
I pulled out trans. and transfer case a couple of month ago, I took pics but
didn't get right detail. Now I'm trying to put it back in and can't figure out
how the transfer case mount and bushings fit to the frame, nothing is lining up for me at this time? It in a 71 chevy 3/4 ton 4X4. Manual four speed trans. Thanks
tractorsx is offline   Reply With Quote
Old 08-03-2007, 08:01 PM   #2
msgross
msgross's Avatar
Re: Need pics. of transfer case mounts and bushings
check out my build thread, should be the same... I can assist with any "detailed" pics that you need.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-03-2007, 08:11 PM   #3
eedgell
It's the air up here
eedgell's Avatar
http://67-72chevytrucks.com/vboard/a...1&d=1186186077
Does this help? NP 205-4 speed, 1971
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 08-04-2007, 09:40 AM   #4
tractorsx
Thanks for the pics both of you guys, I looked at all of them, a couple of them were very close but I could'nt make out what I needed. I'll go outside in a short while and take pics of what I am looking for and what my problem is? I haven't posted pics on this board before, but I'll try. What I'm looking for is the placement of the bushings, and which half is top and bottom, there is a large and small half each?
Old 08-04-2007, 11:22 AM   #5
eedgell
eedgell's Avatar
http://67-72chevytrucks.com/vboard/a...1&d=1186240631
The thicker bushings go between the lower frame rail lip, and the large bracket. The thinner bushings go between the larger and smaller bracket. The smaller bracket is bolted to the center of the frame, and the large bracket from the lower frame lip to the side of the T-case. Hope this helps.
Eric
Old 08-04-2007, 04:08 PM   #6
tractorsx
Thanks a million times for the pics eedgell!!! That was just what I needed. That's how I thought it all fit togather but it just wasn't lining up, in the end I finally had to force some of the bolts in place, didn't like doing that very much, left a few scratches. Anyways THANKS AGAIN.
Old 08-10-2007, 04:40 AM   #7
DURRTY
USMC
DURRTY's Avatar
Hey one of your NUTS broke off. be carefull!!
Semper Fi
DURRTY is offline   Reply With Quote
Old 08-10-2007, 07:37 AM   #8
OLDCHEV4X4
OLDCHEV4X4's Avatar
Mine dont line up perfect either. I have to use a big punch to line up the 5/8" bolts.
205/th350 combo
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 12-26-2024, 07:04 PM   #9
ELVINS
thank you
ELVINS is offline   Reply With Quote
Old 12-27-2024, 11:19 PM   #10
Orange Crate
Orange Crate's Avatar
There are plenty of threads that recommend NOT installing that bracket as it does not allow the drive train to move under torque and that cracks the transmission to transfer case adapter. I left mine off the 72 K20.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks, a 5 speed AND a front hitch!
Orange Crate is offline   Reply With Quote
Old 12-28-2024, 04:46 PM   #11
57taskforce
All about them K’s
57taskforce's Avatar
Yep! I said the exact same thing in the other thread he started on it. I left mine off too.
Tyler
57taskforce is online now   Reply With Quote
Old 12-28-2024, 05:13 PM   #12
Orange Crate
I need to pay better attention to the dates of threads. Why, why why did it take 14 YEARS for someone to say thank you!!!!
Old 12-29-2024, 01:14 AM   #13
kwmech
I need to pay better attention to the dates of threads. Why, why why did it take 17 YEARS for someone to say thank you!!!!
fixed it for ya
