Active Member
![]() Join Date: Aug 2022
1962 gmc rear gas tank options???
So the lmc kit will not work, what have yall done to put a rear tank in a 62??
Thank you!!! |
![]() Join Date: Mar 2016
Re: 1962 gmc rear gas tank options???
I used a 64 Mustang tank. I had to make a mounting bracket because it is narrower than the frame rails but it tucks up nice. The kits that I looked at hung below the bumper and I didn't like that look.
I did a 90's S10 Blazer tank, but the bed floor is also raised 4"
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
I got one from Boyd’s and it’s awesome. I ran a plastic fuel cell for years and it was horrible.
https://fueltankparts.com/collection...hoCp5UQAvD_BwE |
I did the '94 S10 Blazer tank also. It fit between the frame rails, it's 20 gallons and didn't hang as low as some of the others like the standard issue K5 Blazer tanks. It's also FI ready if you choose to go that route...
#6 | |
Active Member
what did you use for a sending unit? and tank fill?? |
Active Member
![]() Join Date: Sep 2016
I did a newer suburban 25 gal. in my 62 Suburban. Changed the spout for the side fill and made a cross suport to hold the "straps" other than that fit great.
More than anything else, I didn't want my rear tank to be hanging below the bumper. I asked this site for help, and the members came through. Here's the thread. http://67-72chevytrucks.com/vboard/s...d.php?t=621177
The tank hanging low was the reason I went the direction I took. I did not want to see the tank from the rear of the truck.
I have the POL 60-62 tank.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
Tanks Inc USPT-GH 15 gal tank. It has two options for fill location. It doesn't hang low and you can buy it with built in fuel pump for EFI.
Unfortunately, I don't have any detailed pics of my setup but it's very similar to SirJim's '62 Suburban. The S10 Blazer tank doesn't hang quite as low though and my straps are hung front to rear.
Active Member
#15 |
#16 | |
I made 4 corner brackets that hold the tank in place and straps underneath. |
#17 |
Active Member
#18 |
Active Member
[attach]
#19 |
![]() Join Date: Oct 2006
Looks great how about a write up?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
#20 |
Active Member
gm sir, its made from 1 x 2 x .125 tube, I spaced it down 1" which puts the fill neck right at the top of the wood for the bed, I bought a lil door kit from tanks inc, the tank is a mustang tank...I can get the the bolts for the bed cross supports from under the frame with a swivel socket.
| Bookmarks |
