All about them K’s
![]() Join Date: Jun 2014
Re: Front Axle assembly swap
No shock mounts need moved on the sqaure body front axles going into 67-72’s. Because your ‘70 was originally an open knuckle 44 axle, no steering mods are needed unless you are lifting. My 72 has a front 60 from an 89 can and chassis K30 converted to single wheel under it.
This axle is 100% bolt in, steering arm, shocks and all. I’ll post a pic if my truck in a bit.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 12-30-2024 at 01:20 PM. |
| Bookmarks |
