Old 09-21-2024, 11:39 AM   #1
Mike_The_Grad
Mike_The_Grad's Avatar
1973 k10 hydroboost conversion questions
Hey everyone, I'm in the middle of doing an LS swap on my buddies 73 k10. We decided to do a hydroboost conversion at the same time because the cam he picked doesn't make enough vacuum for power brakes. I already have the hydroboost unit with matching master cylinder that also matches the power steering pump. I already got the hoses and adapters for the original stock steering gearbox. The hydroboost unit is already mounted to the firewall with a anti rotation bracket that I picked up on ebay. I also found a hydroboost brake pedal assembly on ebay from a squarebody truck. That's all installed. Came with all of the required small parts, I think. Plus a weird bracket that I honestly have no idea where it goes. So my question is, as I try bolting up the little plate bracket for the brake light stop switch, I have to apply pressure to the pedal in order to get the bracket bolted to the pedal. When I do this the little switch stop plate is pressing up against the bracket that holds the actual stop lamp switch. Which is already preloading the hydroboost unit. I don't even have the master cylinder attached to the hydroboost unit yet. And I feel like it will be preloading the unit. Also, I don't even have the switch mounted to the bracket. But I feel like if I try and thread the switch into the bracket the plate attached to the pedal won't let it go very far and might even have enough pressure already to pop the switch back but of the bracket. And in it's current position with the plate attached at the pedal rested on the bracket, the brake pedal is really high in comparison to the accelerator pedal.
This is on 73 k10 with lm7 5.3 and 4l60e and np205 transfer case. Any help or guidance is greatly appreciated as it's one of the last few things before I can get it back on the road.
1972 C/10 LWB - Mine
1964 C/10 LWB - My Dad's
Instagram: Mike_The_Grad
Mike_The_Grad is offline   Reply With Quote
Old 09-21-2024, 01:46 PM   #2
v30crewcab
v30crewcab's Avatar
Re: 1973 k10 hydroboost conversion questions
what is your hydroboost out of? they have specific length pushrods depending on what they were in. the 2000's truck ones won't just bolt in without modifying the pushrod length. you can either cut and modify it, or get one from a 81-87 truck with the correct length.
also, you might need to post a pic of whats going on with your brakelight switch.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 09-21-2024, 05:32 PM   #3
Mike_The_Grad
The hydrobosst unit is from a 1986 1 ton pick up. And so is the master cylinder.
Old 09-21-2024, 06:00 PM   #4
Mike_The_Grad
Here are some pictures. Sorry if it's difficult to make out what parts are what. I'm wondering if I need to use a bracket to space the hydroboost unit off of the firewall to bring the pedal height down closer to level with accelerator pedal. And to not have the unit preloaded. Anybody have a picture of what 1986 1 ton hydroboost unit attached to fire wall looks like?
Old 09-21-2024, 07:07 PM   #5
Mike_The_Grad
Well after some pretzel twisting I was able to take a few measurements. From the inside firewall surface to the loop of the hydroboost push rod I have 8" to center. If I attach the push rod to the brake pedal stud at this point it puts the brake pedal pad about 12" from the floorboard and about 12" from the front of the bench seat. While the accelerator pedal is about 5" off the floorboard. And the brake pedal stop switch contact plate will not even fit the brake pedal arm at this height. BUT, if I were to add about 5/8" inch thick spacers in between the hydro boost mounting plate and firewall on the engine side, this would put the brake pedal pad height about an inch or 2 above accelerator pedal height and would allow enough room for the brake switch contact plate to bolt to the arm assembly and the brake switch to thread into place on the brake pedal pivot housing. I'm wondering if there is supposed to be a spacer plate on the firewall side of the factory hydroboost truck application for 1987 1 ton. Only one way to find out. Here's a question, any reason why I couldn't use spacer bushings on each of the 4 bolts/studs going through the firewall VS. A solid plate to fill the space? Obviously taking stud length into account room permitting for the added spacing. Thanks again.
Old 09-21-2024, 07:24 PM   #6
Mike_The_Grad
Frayed knot my friends. Looks like it's time to get custom. Like we all knew that wasn't going to be the end result anyways. Ha ha. Looks like I'm going to have to cut and shorten the pushrod from the hydro boost unit. I'm thinking of adding a sleeve around the rod to give me some material to bite into with the welder. Plus it'll help with make sure the rod is straight afterwards. I'll be back in a little while to share the end result. Wish me luck. Ha ha.
Old 09-21-2024, 10:34 PM   #7
Mike_The_Grad
Well I cut and shortened the pushrod on the hydroboost unit. Ran out of daylight though. So I'll check the fitment tomorrow. Looks like it should work. I took 9/16" out of the push rod length.
Old 09-21-2024, 11:02 PM   #8
Getter-Done
Getter-Done's Avatar
Nice work.
I hope this works for you.
84 Chevy K-20
Old 09-23-2024, 06:53 PM   #9
v30crewcab
v30crewcab's Avatar
I'm wondering if that little piece is different betweeen vac and hydroboost? maybe different spacing.
71 longbed 5.3 4l80
Old 09-24-2024, 01:59 AM   #10
Mike_The_Grad
The reason why I think it wasn't a direct bolt on process was because the factory equipped hydroboost squarebody trucks had a different firewall mounting area for the hydroboost vs. The vacuum assist booster trucks. In all of the somewhat limited pictures I found online of a hydroboost squarebody equipped truck or a unit pulled from one that still had the firewall plate attached to the unit, they look like they have a raised area or recessed area where they mount to the firewall so that there's room for the big square serrated brass locknut. After I actually looked at what was going on and how I needed to move the unit away from the firewall if I was not going to cut the unit pushrod is when I realized I needed a stepped bracket or plate. Because the lower mounting studs that secure the unit to the firewall are factory pressed in studs and are only so long. Sure I could have taken the whole brake pedal assembly back out, cut and punched out those studs and used longer bolts with washers and nuts, I figured just cutting a small section from the pushrod and welding it back together with a sleeve to have more material to bite into was faster and easier. Which is exactly what happened. It worked perfectly. Pedal is about an inch or inch and half higher in relation to the accelerator pedal. This allowed everything to bolt up just like it should. It doesn't preload the unit, has room for the brake switch to thread in and function like normal. No interference, the pedal works just like it should. It's a big hurdle I've been avoiding for the last couple of weeks. And it finally came time to figure it all out. And I did. I feel like there's not much left in the way of completing this ls swap. Have to get both driveshafts modified. But that's not my job. I just need to get correct measurements and send them off to the driveshaft shop. I already have my hydroboost hoses matching master cylinder, and my adapter fittings for the stock inverted flare power steering box. Connect power steering cooler, fill up all the fluids connect exhaust and fire this bad boy up. here's a couple pictures of the swap. The last picture is what it looked like when it showed up at my house at the end of june.
Old 09-24-2024, 07:17 AM   #11
v30crewcab
v30crewcab's Avatar
on the 81-87 trucks the studs are part of the steering column brace/pedal hanger. guess I need to look at my 79 and see what it has. never had an issue with the hydroboost on the 81 up's. they're basically plug and play.
71 longbed 5.3 4l80
Old 09-24-2024, 10:36 AM   #12
Mike_The_Grad
Yeah I seen that on other guys conversions for the later year sqiarebody trucks. I'm not sure if hydroboost was offered in 73 though.
Old 12-29-2024, 09:51 PM   #13
rawraw67
rawraw67's Avatar
I had question about the brake pedal. what's the different in the pedal.
rawraw67 is offline   Reply With Quote
Old 12-30-2024, 12:17 PM   #14
Mike_The_Grad
There is definitely a difference in the brake pedal assemblies. The entire hanger assembly is different from the vacuum brake pedal compared to the hydroboost assembly. The pivot has a different pedal apply ratio. The pushrod attaching pin is a different diameter and in a different location between the 2 of them. I found a hanger assembly for the hydroboost on ebay for $150. Came complete with every single little part. Some of them i had no idea what they were for and didn't even install them. Mostly because I didn't know what they did or where they went. Ha ha. Got the swap all complete. Runs great, plenty of power. Only problem is the transmission grenaded TWICE on me so far. Within about 300 miles. Both times it's been the pump rotor. So I ended up buying a heated treated 4340 steel rotor. And so far so good. The factory stock rotor is made of pot metal. Literally. And anytime you start putting any kind of horsepower to these things or change to any kind of stall converter they survive about 100 miles. Not the shops fault. It's not a fitment issue. Although yes, some times pump engagement of the converter can cause rotor failures. This is not the case this time. It is important to have between 1/8" and 1/4" of space between the converter and flexplate. If it's more you need to shim it within spec with flat hardened washers, or figure out machining the converter to flexplate or you might have the wrong flexplate for the application.
But now onto the newest issue. Ha ha. The frame rail on the drivers side ahead of the steering gearbox is almost completely cracked all the way around. This has happened within the last 2 months since I finished the swap. Because I had the engine bay completely opened up so I could spray the frame and there wasn't any visible cracks at that time. But there was a repair done at some point I the past because I could see the welds all around the frame around the gearbox mounting location. Problem is whoever did the repair didn't reinforce the frame in that area and less than professional welding job. I found the cracked area by chance tight before I was about to drive it about 100 miles round trip down to Los Angeles. The frame reinforcing plates I ordered from Amazon just showed up yesterday. But I'm in the middle of rewire a 70 gmc 1ton truck and the owner needs that truck by Thursday this week. So plenty of work to be done before next year.
And the owner of the ls swap truck decided he didn't like the intellitronix gauges, which I'm thankful for. They look ok. But they are junk. And difficult to install as compared to the other higher end aftermarket gauge company. The saying you get what you pay for is definitely true when it comes to aftermarket gauges. That's for sure. So the owner decided to go with the new autometer Invision LCD flat screen digital gauges. I haven't installed them yet, but just looking at the quality of the item and the surrounding custom bezel they include for the squarebody trucks. I have to say I'm pretty impressed. And looking forward to installing them soon. I'll post a review when I'm done. And a comparison between all of the aftermarket gauge company's as I've installed all of the most popular brands offerings in 67-72 c10s. this will be the second brand in a squarebody for me.
Here's a picture of the frame.
Old 12-30-2024, 02:31 PM   #15
Keith Seymore
Keith Seymore's Avatar
Hydroboost was not available in '73.
It was available in specific applications for the 1978 model year for C/K truck.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 12-31-2024, 11:05 PM   #16
rawraw67
rawraw67's Avatar
I'm using a 78 hydroboost on my 73 GMC have not yet connected the Pedal. going to look at it Tomorow. Dose any one have a Picture of the hydroboot pedal? sure would like to see what the Pedal looks like.
Old 12-31-2024, 11:35 PM   #17
Keith Seymore
Visually it will look the same, but will be a different pedal ratio.
K
1979-1986
1986 - 2019
