Old 12-24-2024, 11:18 AM   #326
pjmoreland
pjmoreland's Avatar
Re: 1971 K10 Stepside - Getting a Roller Roadworthy
Originally Posted by 396ci View Post
i have a bunch of door glass you can go through.
Sweet. I may end up getting them from Bill of he is ok with disassembling some doors he has. If that doesn't work out, then I'll plan a trip to see you.
pjmoreland is offline   Reply With Quote
Old 12-24-2024, 04:55 PM   #327
'68OrangeSunshine
'68OrangeSunshine's Avatar
Hey Pat and Everybody -- Merry Christmas.
Old 12-24-2024, 04:59 PM   #328
pjmoreland
pjmoreland's Avatar
Thank you, Brian. Merry Christmas to you,, too.
Old 12-30-2024, 10:12 PM   #329
pjmoreland
pjmoreland's Avatar
Working on my truck outside is inconvenient this time of year, so I'm going to focus on tasks that will allow me to roll it into the garage. It is parked on a slope right now, and I'm afraid to try moving it without brakes. I'm going to get the brakes working so I can have my daughter sit in the truck and steer while I push it around.
This evening I removed the hard brake lines and fuel lines from the frame. I will be replacing them with new stainless lines.
Old 12-31-2024, 08:21 AM   #330
CUSTOM/10
CUSTOM/10's Avatar
Hey Pat,
Are buying prebent lines or making up your own ?
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 12-31-2024, 11:22 AM   #331
pjmoreland
pjmoreland's Avatar
Originally Posted by CUSTOM/10 View Post
Hey Pat,
Gary
I bought pre-bent lines.
Old 12-31-2024, 04:22 PM   #332
CUSTOM/10
CUSTOM/10's Avatar
That should make it easier. I bent all mine, and stainless is unforgiving. If you make a mistake on your last bend or forget to put the flare nut on before flaring it's back to square one!!! Ask me how I know..... 😂...
Gary
72 SWB 4x4
My 72 SWB Build
Old 12-31-2024, 04:30 PM   #333
pjmoreland
pjmoreland's Avatar
You probably ended up with better fitting lines in the end though. I debated going that route, but I've bought pre-bent lines in the past, and they fit reasonably well after a little massaging.
Old Yesterday, 10:02 PM   #334
pjmoreland
pjmoreland's Avatar
Spent some time with my dad today repairing heavily worn mechanical clutch linkage parts. We both did some of the welding using his TIG welder, although his welds looked way better than mine. Filed them down smooth and then tempered the welds with an oxy-acetylene torch followed by quenching in water.
Old Today, 12:50 AM   #335
'68OrangeSunshine
That's some skilled welding.
We tried that on the L6 Upper Clutch Push Rod on my Stepside, back about 20 years ago, when we rebuilt the current 292. I abandoned the result, but my Machinist had the idea of threading both ends of a same-length steel rod, and screwing Heim Joints on the ends.
LMC has now 'stolen' the idea, but mine was considerably less, made up from available components.
Old Today, 12:53 AM   #336
pjmoreland
pjmoreland's Avatar
That sounds like an excellent application for Heim joints. How are they holding up?
Old Today, 01:36 AM   #337
'68OrangeSunshine
It was January '05 when Orange Sunshine came back to life with its original engine F0627XAE rebuilt and hotrodded.
The Heim Joint Linkage has given me Zero problems.
[Although I should inspect it tomorrow, so I'm not Jinxed.]
Old Today, 02:09 AM   #338
pjmoreland
pjmoreland's Avatar
Ha!
Old Today, 07:16 AM   #339
CUSTOM/10
CUSTOM/10's Avatar
Yup, Heim joints work good for that application...
Nice work on fixing those worn push rods...
Gary
72 SWB 4x4
My 72 SWB Build
