12-31-2024, 05:41 PM | #1 |
No "Return to Center" Steering Woes
Ok, I’m really getting frustrated trying to get my truck to return to center after a turn. I’ve done the “caster mod” documented many times on this site, moving my LCAs about 3/4” forward. Still no good. Today I finished installing new CPP UCAs that are supposed to provide 5 degrees of extra caster but still no good. The only thing that I can think of to do is put skinnier tires on the front. Right now, I’m running 275/60/15 tires all of the way around. Has anyone solved this problem while running wider tires? Here is what I’m working with:
1964 C-10, 350/TH350 1977 C-10 Spindles Stock LCA with caster mod New CPP 73-87 power steering box Suspension is stock height Last edited by kberger; 12-31-2024 at 06:00 PM. |
12-31-2024, 10:35 PM | #2 |
Re: No "Return to Center" Steering Woes
I was immediately thinking about offset and width of tires while reading your post.
If a set of stock rims n tires are handy put them on and go for a drive for comparison. easy things first, play with front tire pressure up and down. What is the toe set to? Try adding more? If you can, try a drive with power steering belt off, any better ? Maybe you can change pulleys or add a regulator to reduce pressure at the box, get back more steering feedback |
12-31-2024, 10:55 PM | #3 |
Thanks for the reply. Wheels are 15x8 with 4” offset. Stock wheels were 6 lug and now I’m running 5 lug. Toe in at 1/8”. Camber is 0 degrees. I did try upping tire pressure from 44 to 48 psi, no change. Has serpentine setup so can’t remove belt.
01-01-2025, 05:16 AM | #4 |
Saw your other post as well on this. Understand you do not want to spend extra money on checking alignment. But regardless of the mods that you have done, if you do not know the actual caster you have with what you have done. IMHO you are chasing a ghost.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
01-02-2025, 11:40 AM | #5 | |
01-05-2025, 05:27 PM | #6 |
01-06-2025, 04:21 AM | #7 |
If that is measured, great information. Think your steering should be very twitchy. My 2wd 94 only has less than 2 degrees caster with the 5" lift I put on. Steering is a bit lazy, but returns to center no problem. Have custom made upper arms to install to get caster back, just have not installed. See later model spindles were mentioned. What are rest of steering components that connect to them? Center link, end links? Reason I mention is this post here https://67-72chevytrucks.com/vboard/...d.php?t=853016 Maybe check other components.
01-06-2025, 10:28 AM | #8 |
I would question that number. Why is it so aggressive vs the OE specs range?
This era of trucks (63-87) suspension typically called for 2-3 POS degrees Caster w/most never reaching the 3° mark. Aftermarket parts & some clever tweaks to the stock stuff can boost the Caster number to yield a more aggressive 5-7 POS degrees. To surpass double of that range = scrutinizing things & figuring out how that number/range was achieved.
01-06-2025, 12:56 PM | #9 | |
I'm not purposely trying to be that aggressive on caster, just trying to figure out why no return to center. |
01-06-2025, 12:59 PM | #10 | |
01-06-2025, 01:48 PM | #11 | |
Is that additional Caster impacting the effects of the steering axis/geometry side of things cycling L-to-R @ the lower speeds associated when making turns (where the steering is expected to return to center vs changing lanes type of turn)? Personally, since you forked over the $$ for those CPP arms, I'd put the lower control arms back where they're supposed to be. Get the alignment closer to the aggressive limit for Caster (+7° is aggressive) & see if there's a difference.
01-06-2025, 01:59 PM | #12 | |
01-06-2025, 02:02 PM | #13 | |
01-06-2025, 03:23 PM | #14 |
This could be mechanical, not alignment.
A binding balljoint, tie rod, idler arm, steering column/joint or A badly setup steering box; setup too tight or a bad PS valve or Something installed wrong giving bad geometry as suggested a couple posts up even if all this stuff is new I'd do some checking |
01-06-2025, 03:47 PM | #15 | |
For testing, jack the front up & block both sides up (under the a-arms) w/the tires barely off the ground. This would replicate weight on the suspension w/o having the resistance of the vehicles weight on the ground/road impacting things. Cycle the steering by turning L-to-R & see how the wheels pivot @ the spindle? How is the resistance @ the steering wheel when turning each way? Is it consistent for both directions? Disconnect the TRE's & repeat the testing again @ the hub. Rotate each side back & forth L-to-R & feel for possible binding @ the BJ's (I've heard of more than one vehicle w/new parts causing issue). Eliminate this stuff as a possibility. I request my trucks to be set up @ static NEG .5° Camber w/as much Caster as possible w/o impacting that Camber target. I like the impact it has on grip in corners. I rely on others doing the alignment (@ commercial places of business) so I've never had the ability to thoroughly ID full Caster/Camber results through the range of travel. While there's no confusing them as a Vette, both of my lowered HD trucks ('99/OBS 3/4-ton CC SWB & Squarebody CC Dually) using the above alignment target specs handle much better vs their stock height/stock alignment specs in comparison & this is w/both still usng steel 6" wide front wheels/narrow tires. Both feel planted w/o much (any?) understeer & steering return to center + input feel is nice/consistent.
01-06-2025, 04:12 PM | #16 |
Here are some pics of my setup
01-06-2025, 04:14 PM | #17 |
A few more. I have jacked up the wheels and turned wheel lock to lock without any binding or significant resistance. Removing TRE and checking BJ stiffness is a good idea.
01-06-2025, 04:34 PM | #18 |
Are you testing for binding from the steering wheel or at the tires?
With it jacked up and motor running does the steering stay where you put it or creep? (bad PS valve) If you have a place where you can do it safely you might try doing some downhill motor off turns, see if it wants to center without PS. When you upgraded to the PS box, how did you align the box on the 64 frame? Did you use a spacer or put a bump in the frame? Is the steering arm on new box in same geometry as the old one was? Did you replace the idler arm/ redrill it's mounts? Is the center link horizontal relative to frame? is it parallel to a line through the ball joints? Any chance you have a bent spindle, steering or control arm? |
01-06-2025, 04:57 PM | #19 | |
Box is lined up as original Idler arm is '64, located in original position I don't believe anything is bent. I checked for binding at the steering wheel, motor not running |
01-06-2025, 05:34 PM | #20 |
I'm not familiar with it, does the REZ kit include a spacer so the box clears the frame? Do they say anything about adjusting idler arm?
FWIW: I have a 64 frame under a '52. I converted to PS last winter with an early 80s suburban box. I DIY'd it but layed out redrilling the frame so the end of the steering arm was in matching spot and the box remained in alignment. About 1/8 spacer, ground the casting seam off box plus some clearance into the frame to clear the bump. I did not change my idler to the newer, longer style. My center link is slightly off level. I'm switching to disks and newer control arms this spring and will address the idler at the same time. It rode and turned OK, drove it all summer and into fall. There IS a tendency to hold a gradual sweeping turn and not return to center. It did not bother me, knowing I had further plans for this winter. I run 225 front tires. The alignment is tape measure and level done in my not very flat driveway. Camber about right, 1/16 toe and very little caster maybe a degree. But I don't put a lot of faith in the accuracy of those numbers. I might have some play in a CA bushing, I hear a clunk but can't find any movement. Truck does have some noises to it. The 80s 'burban PS box plus an unknown origin pump provides a lot of steering assist. Like park with one finger easy to steer. It could use less so there was more feedback. I'd check all your components for binding under load and pay some attention to geometry of the steering gear. Are you confident in your alignment shop? |
01-06-2025, 07:25 PM | #21 | |
01-12-2025, 02:48 PM | #22 |
Can we see a picture of the shim stacks on the upper control arms?
And can you post the alignment print out after the alignment? When you did the Caster Mod how far from the end of the lower shaft did you drill the the new index hole?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 01-12-2025 at 03:15 PM. |
