Old 01-01-2025, 01:00 AM   #1
dmcclanahan
C30 lift spindles
Im looking lift my 1986 Chevy C30 1ton 2wd truck. Im trying to find lift spindles to make this happen. I currently working with all stock parts.
dmcclanahan is offline   Reply With Quote
Old 01-01-2025, 02:02 AM   #2
smupser
Active Member
Re: C30 lift spindles
There’s a recipe on here for a 2wd lift that utilizes 88-98 lift spindles, should be able to work on your C30.
smupser is online now   Reply With Quote
Old 01-01-2025, 03:40 AM   #3
dmcclanahan
Do you have a website?
Or know where I can find them?
Old 01-01-2025, 06:29 PM   #4
kwmech
I got almost an inch and half lift on my dually just by replacing the front springs. The one tons are hard on them if you use the truck as intended. Mine used to be a class b motor home
Old 01-01-2025, 09:41 PM   #5
smupser
Active Member
It’s a thread on this website, I’ll try to find it
Old 01-01-2025, 09:43 PM   #6
smupser
Active Member
Here you go
https://67-72chevytrucks.com/vboard/...d.php?t=447061
If your truck is a dually I’m not sure if you can make this work
Old 01-01-2025, 10:17 PM   #7
dmcclanahan
Yes I have a dually set on mine.
Old Today, 05:06 AM   #8
Ziegelsteinfaust
Arn't the P30 spindles good for a inch over normal spindles
Ziegelsteinfaust is offline   Reply With Quote
