Old 01-01-2025, 04:25 PM   #1
zicc1835
zicc1835's Avatar
ID the block
these are the numbers stamped on the pad on the front of the block I can't get a camera in to see casting numbers Power Glide kick down bracket is in my way ...im searching .....this is a 69 c-10 half ton and the glide is original and on the SPID I didn't and can't get any info from the PO or the PO before him someone did a recent resto that's just OK .... the heads are interesting and what's got me wondering 327 ....69s came with IL6 307 350s not sure or is this a early 69 with a leftover 327 ??? or a 350 that's been upgraded some what ?
PS in my younger days if you had the number stamps you could put any Id# you wanted on that pad
zicc1835 is offline   Reply With Quote
Old 01-01-2025, 04:36 PM   #2
zicc1835
zicc1835's Avatar
Re: ID the block
I looked here ????? I know no more now than I did before
https://nastyz28.com/sbchevy/sblock.html#ecode
Old 01-01-2025, 05:45 PM   #3
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Re: ID the block
Can't tell you about the block, but those are Fuel Injection/high performance heads.
~Steven
Simi Valley, CA
Old 01-01-2025, 06:20 PM   #4
zicc1835
zicc1835's Avatar
Re: ID the block
thanks yes I know! that's exactly why in trying to identify the block they are sitting on... when I get some time ill take a V cover off and see what flavor the heads are you probably know better than I they made a few versions of thus HUMP Heads
Old 01-01-2025, 06:28 PM   #5
72c20customcamper
72c20customcamper's Avatar
Re: ID the block
Never mind
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 01-01-2025, 06:33 PM   #6
zicc1835
zicc1835's Avatar
Re: ID the block
beat me too it
Old 01-01-2025, 07:59 PM   #7
Steeveedee
Steeveedee's Avatar
Re: ID the block
Those will have 2.02/1.60 or 1.95/1.60 diameter intake/exhaust valves. Not sure there is any way to tell by looking at the casting numbers, but it's been a dog's age since I worked with anything like that...like 30-40 years. There isn't much room inside the head for the 2.02/1.60 valves. They are really close to each other and the thin area was prone to cracking.
~Steven
Simi Valley, CA
Old 01-02-2025, 12:42 AM   #8
RustyPile
RustyPile's Avatar
Re: ID the block
Using the last 3 digits (letters) of the stamping, search here for the original configuration, year of the engine, and what vehicles it was installed.
http://camaros.org/pdf/LimeBook.pdf
RustyPile is offline   Reply With Quote
Old 01-02-2025, 09:39 AM   #9
Mike C
Mike C's Avatar
Re: ID the block
What I could find is the HC suffix code was for a 65-66 250hp 327 with 4 barrel carb and power glide transmission. This would most likely have been in a Chevelle. This was in the era of 2 digit suffix codes, but for some they had 3. HCH was the same engine with a Holley 4 barrel and HCR was the motor with a Rochester.
This was an interesting find as I had not seen that before. You learn something new all the time.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-02-2025, 10:26 AM   #10
MARKDTN
Re: ID the block
Intake is '68 and back with a plug in the filler hole. Can you see a date on the intake?
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 01-02-2025, 09:38 PM   #11
zicc1835
zicc1835's Avatar
Re: ID the block
I will look tomorrow thank you
Old 01-02-2025, 09:50 PM   #12
zicc1835
zicc1835's Avatar
Re: ID the block
I appreciate all of you helping with this.... learning all the time too I knew that plugged manifold meant something just didn't know what...... what makes this board and its members who we are and always looking to help
thanks again we will come to a conclusion (break the code) on this at some point I now have to look at the carb see if its a ROTENCHESTER to be continued
Happy Healthy New year to all
Old 01-05-2025, 06:53 PM   #13
zicc1835
zicc1835's Avatar
Re: ID the block
numbers of the carb comes back 1974 Chev
Old 01-05-2025, 09:58 PM   #14
RustyPile
RustyPile's Avatar
Re: ID the block
The heads and block are "numbers matching".. It appears that at some point in the past, the carburetor was changed..
Old 01-05-2025, 10:25 PM   #15
dmb
Re: ID the block
1966 327 275 hp roc. carb powerglide trans very common back in the day, hard to find now
dmb is offline   Reply With Quote
Old 01-06-2025, 07:43 PM   #16
Accelo
Accelo's Avatar
Re: ID the block
"What I could find is the HC suffix code was for a 65-66 250hp 327 "
Did I read the suffix as HCR? That would make the block build after 1970, when GM went to a three-letter suffix, as they had used up all the two letters. Would know more if the block casting number wasn't hidden from view by the bracket for the PG kick-down.
The heads were manufactured with 2.02 and 1.94 valves. If you install 2.02 valves in this head, they will flow less than in the 1.94 valved head. The reason is GM cut back the chamber on the 2.02 heads on the intake side only. This unshrouded the valve so the larger valve to flow correctly. Very few conversions have the chamber machined. Typically, I just see it on the factory 2.02 heads. There is a tool to cut back the chamber wall, but most machinists do not bother.
Accelo is offline   Reply With Quote
Old 01-06-2025, 08:02 PM   #17
zicc1835
zicc1835's Avatar
Re: ID the block
thanks for that info.... im going to get to that casting # on the block one way or another and the intake # too
Old 01-06-2025, 11:45 PM   #18
dmb
Re: ID the block
the hcr code is 1966 327 275 hp and that is for sure lol
Old 01-06-2025, 11:52 PM   #19
BROWN 70
BROWN 70's Avatar
Re: ID the block
hi, post 15 is correct. I found the same thing, BROWN 70
BROWN 70 is offline   Reply With Quote
