Old 12-31-2024, 05:44 PM   #1
lolcopter
700r4 won't shift at WOT
I have a 700r4 behind a gen 6 454. The transmission is recently rebuilt along with everything else for truck.
At wot the transmission won't shift in any gear. If you let off slightly it will but when you go back full throttle it wants to downshift regardless of rpm. I replaced the weights and springs on governor and cleaned it well with no change. The part throttle shifts are perfect.
I'm not sure if I need to adjust the TV cable out some but at the same time don't want to mess up the perfect part throttle shifts.
Any help would be greatly appreciated.
lolcopter is offline   Reply With Quote
Old 12-31-2024, 08:07 PM   #2
weq92f
weq92f's Avatar
Re: 700r4 won't shift at WOT
Pull the servo, measure it and determine which one is installed. In my case, 1-2 shift would not happen at WOT but was fine at lighter throttle. The servo I had installed was the second weakest one. After I updated that to the full GM "Corvette" servo, WOT 1-2 shift cleaned right up. It will now do a light throttle 1-2 chirp of the tires (posi) if on the right kind of pavement. WOT 1-2 shift happens now...but I'm sure my driving it with a 4cylinder rated servo burned the clutches a bit...and that's why it's not as firm as I'd like. It does shift though which was the desired results.
EDIT: In my case, adjusting the TV tighter by a click didn't help the WOT shift issue, however it is an easy test and is worthwhile.
Hth,
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 12-31-2024, 08:50 PM   #3
lolcopter
It has a Corvette servo in it. Replaced that when it was rebuilt then again after it was installed. Nothing changed.
Old 12-31-2024, 10:42 PM   #4
kaycee
kaycee's Avatar
The cable is kinda tricky, it fees like the cable is tight at idle but there is a small void before the cable actually starts to pull on the cable.You can feel the void when you pull on the cable.You can feel it about an 1/8” after slack is pulled .Try it with it unhooked from carb and car is off. That’s why I use a press. Gauge you can see the press. Rise as soon as your off idle. Hope I made sense trying to explain this Good luck
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 12-31-2024, 11:52 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
The one vehicle I had with a 700 trans, I pulled the cable up and matched it to WOT. If yours is staying in a lower gear, back off the adjustment a little, until it doesn't. FWIW, if the cable is too tight, you ain't getting WOT, anyway.
~Steven
Simi Valley, CA
Old 01-01-2025, 12:56 PM   #6
kaycee
kaycee's Avatar
YEAH IT takes some to get it all correct , this is very critical to get right (been there done that). I used a BTO TV kit on my 69 pricey but well worth it ,on my 63 I used a stock setup .
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 01-01-2025, 07:27 PM   #7
lolcopter
It has all the right adapters for the Holley carb and mounting brackets. Normal driving it shifts perfect if not a little early. It's just wot it won't shift at all.
Old 01-02-2025, 10:50 AM   #8
Rickysnickers
Then, is your gas pedal pulling the cable all the way?
Old Yesterday, 09:59 AM   #9
lolcopter
Yes it's pulled completely tight where I can't pull it anymore at wot. Could it be pulling it to far?
Old Yesterday, 10:21 AM   #10
Rickysnickers
I don't know the answer to that question, sorry. I was just asking so that you are sure the gas pedal has full travel.
