Old 12-31-2024, 06:03 PM   #1
kberger
No "Return to Center" Steering Woes
Ok, I’m really getting frustrated trying to get my truck to return to center after a turn. I’ve done the “caster mod” documented many times on this site, moving my LCAs about 3/4” forward. Still no good. Today I finished installing new CPP UCAs that are supposed to provide 5 degrees of extra caster but still no good. The only thing that I can think of to do is put skinnier tires on the front. Right now, I’m running 275/60/15 tires all of the way around. Has anyone solved this problem while running wider tires? Here is what I’m working with:
1964 C-10, 350/TH350
1977 C-10 Spindles
Stock LCA with caster mod
New CPP 73-87 power steering box
Suspension is stock height
kberger is offline   Reply With Quote
Old 12-31-2024, 07:41 PM   #2
SkinnyG
SkinnyG's Avatar
Re: No "Return to Center" Steering Woes
Do you have alignment numbers?
Are the control arms on the correct side?
Is the steering box adjusted too tight?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 12-31-2024, 09:50 PM   #3
kberger
Arms are most definitely on the correct side. Steering box is new and I haven’t made any adjustments to it. Previous steering box performed exactly the same. Camber is near 0 degrees, toe in at 1/8”. Don’t want to have professionally aligned until I get this solved.
Old 12-31-2024, 11:32 PM   #4
dmjlambert
dmjlambert's Avatar
Perhaps post pictures of your steering setup and somebody notice something interesting.
Old 01-01-2025, 08:37 AM   #5
SkinnyG
SkinnyG's Avatar
You can get some reasonable numbers by yourself with a simple inclinometer app on your phone.
I'm a shop teacher by trade. I explain wheel alignments in THIS VIDEO, and talk specifically about Caster at the 9:30 mark. See if this helps you at all.
Old 01-01-2025, 09:30 PM   #6
cwcarpenter98
cwcarpenter98's Avatar
Also, double check that your center link is installed in the correct orientation. They can be installed backwards which will cause all sorts of drivability issues
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-02-2025, 12:40 AM   #7
Johnie
I have the same problem and the same setup. I set the alignment with angle finder, string and tape measure. Then had it aligned at a shop. She runs down the highway straight and smooth with no wandering. But it absolutely will not return to center on its own. The streering is very light - and i suspect the box is the problem with mine. While looking for a solution I found some good info about this on the Borgeson web site:
https://www.borgeson.com/steering-sy...esign-and-tech
1964 C10 Long Bed Step Side
Johnie is offline   Reply With Quote
Old 01-02-2025, 12:56 AM   #8
dmjlambert
dmjlambert's Avatar
Pictures of the setup are a good idea.
Old 01-02-2025, 01:50 PM   #9
bigmoe
bigmoe's Avatar
Those tires are pretty wide in front. I'd throw on some narrower wheels/tires just to rule out that the width is the problem or is contributing.
bigmoe is offline   Reply With Quote
Old 01-02-2025, 10:07 PM   #10
caseyjones
I had a poor return to center feel, and kind of a notchy feeling in the steering...turned out to be the nearly-new AC Delco "gold" ball joints. Replaced with MOOG and the issues went away.
caseyjones is online now   Reply With Quote
Old Yesterday, 12:14 PM   #11
kberger
Attempting to attach pics. Wow that actually worked, I will add more detailed pics this weekend. Also, I'm running about 15 degrees of caster.
