01-01-2025, 11:55 AM | #1 |
53' GMC 3 on the tree help
Hi Team i am in the process to fix a 53 Longbed GMC truck with a GMC 228 engine.
We opted for a CLIFFORD intake with headers and a Weber 38 carb for a bit more performance. The truck spend his last years in PAINTJAIL , the painter disassembled the Truck and now i piece the Puzzle together . the Engine is running, It has New wiring, got converted to Throttle cable and i am in the process of putting the Clifford kit on it. As expected i run into issues with the Shifter 1st issue the shifter was disconnected so i am trying to figure out the linkages. i would like to find a diagram and how to correctly position the Shift lever on the steering wheel. I can also see that the linkages on the Steering shaft will hit the Clifford intake. How have you guys solved this? We already considered a Floor Shifter?< if so what floor shifter do you recommend? Further the CLUTCH PEDALK LINKAGE to the trans was disconnected . DO you have any pics of the correct Linkage that i might have in all the Parts bins that came with the truck? if not whats a good replacement part. please see some pics attached i am located in DFW TX |
01-02-2025, 01:58 AM | #2 |
Re: 53' GMC 3 on the tree help
A 53 foot long GMC?
01-02-2025, 04:11 AM | #3 |
Have you looked into the feasibility of leaning the engine over toward the passenger side just enough to gain clearance??
01-02-2025, 02:07 PM | #4 |
01-02-2025, 05:26 PM | #5 |
Isn’t a 53footer considered a short box!
The best floor shifter is a hurst master shift. Like this one. https://www.summitracing.com/parts/h...yABEgIM7fD_BwE |
01-03-2025, 12:42 AM | #6 | |
Will the trans existing linkage bolt right up? |
01-03-2025, 10:19 AM | #7 |
Nope.
You also need a kit with the brackets and rods to set up a floor shift. Like this. https://www.holley.com/products/driv...shift_3-speed/ |
01-03-2025, 11:35 AM | #8 | |
I hope it clears teh bench seat accordingly. i will look up which trans we have exactly to get the right linkage and shifter... PS the clutch pedal linkage is missing too the fork doesnt get engaged , i have to source that one too... |
01-03-2025, 11:49 AM | #9 |
Shifter handle can be tight to the seat but there’s a cure for that with a shifter like this.
https://www.shifterdoc.com/productca...-Seat-p277.htm |
