12-12-2024, 01:09 AM | #576 |
Re: norms 55 chevy pu build
that looks AWESOME! must feel pretty good to be at that point. i wish I were that far along.
love that color, great choice. |
12-14-2024, 10:36 PM | #577 |
Just wondering, can I put the front fenders on and put the inner fenders on after, or must I put them on assembled?
Or do I put the inner fenders on first? In the past I always put them on assembled but they were not painted so bumps and scratches didn't matter. Wish I would have practiced "pretending they were painted" to assemble once or twice. |
12-17-2024, 01:13 AM | #578 |
since the inner fenders bolt to the rad support I would think they gotta go on first. unless, of course, you have some help to assemble stuff and someone could hold a few things while you mve parts in or out. it might be better to assemble the inners first though and then the fenders. I like to use wide masking tape on the edges and corners until the parts are loosely bolted up. there is also plastic washers that can be used between parts or under bolts so as not to crack or damage new paint. usually available at bolt supply places or online.
post up some pics as you go, it helps inspire the rest of us. |
12-17-2024, 08:26 AM | #579 |
DSRaven is exactly right. The inner fenders are sandwiched between the radiator core support and the fender so you will have to either bolt the inner fender to the fender first or as he said have a helper to help hold it in place so that you can bolt the fender through the inner fender and into the core support at the same time.
12-22-2024, 03:25 AM | #580 |
Had my wife help steady it and we got the hood on. Seems every piece I put on this thing, the shop gets just a little bigger, lol.
12-22-2024, 10:54 AM | #581 |
Looks great.
At first glance I thought you had some sort of a jib crane on your tractor. Haha. |
12-22-2024, 10:56 AM | #582 |
You're probably aware but the doors get fit to the cab first before fenders go on.
I like to use some tape on the edges of the panels that may accidentally contact each other upon assembly and adjustment. |
12-22-2024, 12:33 PM | #583 |
I now see what you are saying about a crane on the tractor, lol.
My plan with the doors,, I had parts all over the floor in the shop with towels under them, leaving me very little space to move around. I had to walk so carefully it was stressful. I did not want to constantly move all those parts because of chip risk. This meant my hoist did not have room to be used. Example, I put the cab on outside where there was unlimited room. I have the hood mounted as far forward in it's mounting holes as I can, leaves me 1/2 inch of clearance between hood and firewall, I'll do the same with the front fenders. I am going to use the hoist to hang the doors so I have total control and can slide them in place 1/2 inch at a time without getting tired from lifting, or balancing them on a jack, risking dropping them. With all the other painted stuff on the pu I will have room to have the hoist 90 degrees to the cab, that takes about 15 feet of width room, and my shop is 20 feet wide. Once the doors are hung and adjusted to the cab I'll start moving the fenders and hood back as needed. Before paint I had the doors on and off several times to work on them with fenders mounted, so I kinda learned how to do that. I spent extra time sanding and painting last summer to get everything sprayed, this way, my little paint room could be used to store parts this winter because my snow moving tractor takes up lots of room. Now, when everything's mounted, I have room to move my hoist around inside. Last edited by washington blue; 12-22-2024 at 04:13 PM. |
12-22-2024, 12:36 PM | #584 |
Very nice work. I can't wait to see the fenders and doors on.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
12-22-2024, 12:46 PM | #585 |
Put the inner fenders on, there are 2 bolts at the bottom, 1 on the core support and 1 all the way at the lower back. The inner fenders are very light so those bolts keep them in place nicely. Once I'm done sanding, buffing the fenders I'll see how it goes putting them on,lol.
In the picture you can see a bolt at the top of the core support, I put it there so I know where it is. It's not holding anything. |
12-22-2024, 12:48 PM | #586 |
Here's hoping everyone is getting ready for a wonderful Christmas in a few days.
12-22-2024, 04:15 PM | #587 |
I'm starting to think my front springs might be a tiny bit too strong, it has not settled at all yet. I have another 300 pounds or so to put on it yet tho.
12-23-2024, 09:55 AM | #588 |
Looks Great!! Doing the fun stuff now. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
12-23-2024, 11:10 AM | #589 |
don't worry about the springs till its all together and has been driven around for a bit. sometimes new springs take a bit to get their "set" and if they end up too strong they can be swapped out, after the truck has been finished, without too much work.
keep plugging away at it and you'll soon have all kinds of room in your shop and only left over extra parts left laying around. it's coming out nice. |
12-23-2024, 11:58 AM | #590 |
Thanks guys.
Ok, I'll try not to think about springs, I tend to be a little bit of a worrier, It occured to me that I had never compaired the front weight of a 80 Firebird to a 55 pu with alterations. An 80 Fierbird weighs 3400 pounds. I guess I still have lots of things to put on that will add a few hundred pounds. These are the origional "80" springs. |
12-23-2024, 07:08 PM | #591 |
you probably could spend a bunch of time researching but, in the end, it will come down to how it sits when completed. if the springs in the camaro clip are original springs and it sits high then you could possibly swap then for some lighter springs or adjust the rear to match the height. if it is a rough ride quality then you could swap the coils.
12-31-2024, 01:37 AM | #592 |
I got done sanding and buffing and polishing the front fenders. My daughter is home from college so I had her and my wife and I put those front fenders on. This is with the inner fenders in place. Had all the bolts loose and with some wiggling we got them on with no damage, at least none yet, knock on wood. There will be tons of adjusting and shimming to do later. Cannot close the hood until lots of adjusting is done. But, Not going to worry about any of that until after the doors are sanded buffed, polished and installed. That will be a while, more sanding and more sanding to do yet.
12-31-2024, 01:46 AM | #593 |
Use lots of tape on the edges of the doors and fenders. It's a job putting doors on so have help when the time comes. Looks really good.
12-31-2024, 09:11 AM | #594 |
It really is looking good. More sanding, yuck! But it will be worth it.
01-04-2025, 09:44 PM | #595 |
I finished sanding, buffing, then polishing 1 door. Now I have 1 door left, so half done with doors. gaining, lol.
01-05-2025, 01:27 AM | #596 |
Do you plan to install, then assemble the doors? Sometimes easier that trying to assemble off the truck and not scratch the new paint in the process. Lighter to install too. Also, no latch to mess with the door adjustment.
Looking good. Sure wish I were that far along. My project goes in spurts, a blitz then nothing for a long time while life interferes. |
01-05-2025, 12:41 PM | #597 |
Yes, I am going to install them stripped as they are. The less weight the better, even though I'll have them hanging from my hoist. They will be held solid on the hinges instead of sitting on the floor to wiggle windows and latches into place. I had them mounted on the hinges the first time I put glass and latches together, so I'm kinda used to that.
Yes not having door latches makes it easier to ease them mostly shut to check alignment so I'll do it that way. Been so long since I had the doors all assembled I've kinda forgotten how the glass goes in, probably scratch something, lol. I have new vent windows but I need the big door glass, where's the best place to get it? Thanks. |
01-05-2025, 12:58 PM | #598 |
DS, I have the problem of not being motovated a lot of the time too. I developed a rule that when I'm not busy with farming I must do at least 1 hour each day in the shop.
That 1 hour kinda replaces the livestock chores I used to do, it's pretend I know, but livestock chores were in the cold, wet, snow and wind, so I tell myself shop work is a treat, which it is really. Usually that 1 hour turns into 5 or 6, once I get my butt out there it seems time goes fast. My shop is always heated so that helps, I turn the heat up to 70 degrees when I'm there, otherwise it's 59. That comfort helps too. I don't want to be one of those old guys that sits all day so I'm going to keep building stuff as long as I can, I think the planning, worrying/stress and activity helps keep me sharp. |
01-05-2025, 01:18 PM | #599 |
Nice work on that door. You have more patience than I do.
Funny you talked about motivation to go to the shop. My wife said when I retired, I didn't, I just go to the shop now. I do go there almost every day, but some days it's just to look and think. I'm still figuring out what I'm doing, and sometimes I forget what goes where, because I don't always take good notes or use labels. I had the ACME glass here in town make my one-piece window for my 48. I started with a piece of 1/4" plywood and kept shaving it down until it fit. They made glass that matched it, and they work pretty well. If I had it to do again, I'd find some online. It was a pain.
01-05-2025, 11:32 PM | #600 |
Yeah, 8man I have a thinking chair in the shop, sometimes I think a lot in it, lol.
I am terrible at taking notes or bagging and tagging stuff. I do try to keep all my small stuff on 1 set of shelves, problem is right now they are behind where I have my doors set so I can't get to a lot of it. I suspect my door hinge bolts are behind the doors right now, dang it. I'm kinda hoping to find some glass on line too. I got my vent windows from H&H classic parts, IDK if they are the best or not but the vents seem fine. Last edited by washington blue; Yesterday at 03:25 AM. |
