Old 01-04-2025, 08:41 PM   #1
msg
Glass setting tape recommendations?
Anyone had good results with any particular tape to set the door glass into? i have seen some that have cork as part of it and some that are just butyl I guess.
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is online now   Reply With Quote
Old Yesterday, 12:36 AM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Glass setting tape recommendations?
I don't know what my local glass shop used, but the vent windows and side windows that I had them re-set haven't budged a bit since then
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old Yesterday, 10:20 AM   #3
55-72 GM trucks
Active Member
fixing to try the tape classic parts of america sells for vents but my glass shop said to use black silicone so I did that on my 58 and it came out perfect on door and vents but if you ever wanted that glass out again I bet it would be nearly impossible to remove
55-72 GM trucks is offline   Reply With Quote
Old Yesterday, 11:43 AM   #4
rideblue00
rideblue00's Avatar
I used the glass setting tape from Classic Parts and it worked fine.
rideblue00 is online now   Reply With Quote
Old Yesterday, 03:23 PM   #5
GMCPaul
We carry the OE style glass setting tape in 3 thickness's
Part # 20077682 Glass Setting Tape
Professional weatherstrip glass setting tape. This is the material for installing vent window glass into metal frame and for installing door glass into the lower door sash metal channel that it rides on. This kit includes 2- 30" pieces that are 1" wide. Available in 3 different thickness, 1/16", 3/64", or 3/32" thick. Select thickness desired after adding to cart.
Manufactured by Precision
https://gmcpauls.com/60-66rubber_weather_strip.htm
Paul Jr @ GMCPauls
GMCPaul is offline   Reply With Quote
