Old 12-22-2024, 09:54 AM   #26
7dee2
7dee2's Avatar
Re: 72 C10 Build
Originally Posted by raggedjim View Post
Thanks, looks like it makes getting access much better.
I think it does for several areas, and if you don’t have a rotisserie (which we didn’t at this time) not having to work overhead is a win.
Wasted no time starting to cut, the Sawzall makes short work finding good metal.
Brett
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 12-26-2024, 10:09 AM   #27
7dee2
7dee2's Avatar
Re: 72 C10 Build
Same for the other side.
Brett
Old 12-26-2024, 08:42 PM   #28
LockDoc
The Older Generation
LockDoc's Avatar
Re: 72 C10 Build
Looks like you are making some good progress. Keep on it and keep us up to date....
Leon
Old 12-29-2024, 09:35 AM   #29
7dee2
7dee2's Avatar
Re: 72 C10 Build
Thanks Leon! Yeah, we wasted no time getting into the metalwork on this one.
We hit the top of the cab (both inner & outer) with a DA sander. Then we got the cab upright and placed it on a raised diy cab dolly similar to one built for the bed. It’s high enough to make working on the lower part of the cab comfortable. I love stuff on wheels, especially when space is limited.
Brett
Old 12-29-2024, 09:44 AM   #30
raggedjim
raggedjim's Avatar
Re: 72 C10 Build
Being able to move things around helps a lot!
raggedjim is offline   Reply With Quote
Old 01-01-2025, 01:24 PM   #31
7dee2
7dee2's Avatar
Re: 72 C10 Build
Ain’t that the truth, it seems like every weekend we were moving stuff around to make room for workspace or parts or something.
The bed is in great shape overall, just needs the front panel replaced and minor floor attention. Our doors are fairly nice also, the left one is better than the right. The right door has a spot of rust and some damage to the lower back side of the inner shell. It also looks like it may require a new skin we’ll see.
Brett
Old 01-01-2025, 02:53 PM   #32
raggedjim
raggedjim's Avatar
Re: 72 C10 Build
Better than the crap I drag home!
Old 01-05-2025, 09:22 AM   #33
7dee2
7dee2's Avatar
Re: 72 C10 Build
A lot of the body panels are good, surprisingly good for living in Utah its whole life.
Took a grinder to the 2-tone cab divider studs, more on this decision to follow later. Nothing too out of the norm on the back of the cab except that same evidence that it was hit on the lower right rear corner. With signs that the cab’s been pounded back out in that area a light bulb came on. I should take a closer look at the right bedside. Yes, it appears to have been replaced with a factory (?) bedside.
Brett
Old 01-05-2025, 03:35 PM   #34
clay68c10
clay68c10's Avatar
Re: 72 C10 Build
Nice progress! Good decision on having the cab blasted. I stripped mine myself and it was a ton of work.
Double check your door fitment on that R side. It doesn’t take much to move that cab opening around. I thought I had mine good, but a similar hit on my L side had me cutting the door edge to get a nice fit. Luckily it was still in the bodywork stage.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old Yesterday, 10:36 AM   #35
7dee2
7dee2's Avatar
Re: 72 C10 Build
Thanks, media blast is way more aggressive than stripper but it is a whole lot quicker. Pros and cons to both for sure.
I couldn’t find anything wrong with the left door; there was just a little mud on the outer skin. I think this one is good to go for now. The truck shows it’s had at least one complete exterior repaint in its life.
Brett
