Old 01-08-2025, 11:15 AM   #1
AZBuckHunter
AZBuckHunter's Avatar
71 C10 Crossmember Identification Help
Good morning.
I'm hoping somebody can help me identify the crossmembers in my 71.
I recently removed a 350/350 combo to do some upgrades and cleanup. I realize that was not the stock application.
As pictured below, I have labelled 4 crossmembers.
1 = Frame Brace?
2 = Engine crossmember
3 = ?
4 = TH350 transmission crossmember
My question is, does crossmember #3 need to stay or was it for a previous manual transmission? I'm hoping to just be able to grind the rivets and remove #3 while leaving the rest in place. I'm staying with a th350 transmission like I removed.
If you have a good eye, you will see #3 is torch cut on the right side rear portion where it mounts to the frame. The shift linkage for the th350 was mounted there where its cutout.
Thank you
AZBuckHunter is offline   Reply With Quote
Old 01-08-2025, 11:37 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 71 C10 Crossmember Identification Help
Originally Posted by AZBuckHunter View Post
Good morning.
1 = Frame Brace?
3 = ?
Thank you
Yes, that Xmember is for the bell housing mount for manual transmissions. You can remove it.
Leon
Old 01-08-2025, 11:47 AM   #3
Classic Bowties
Always on the hunt...
The x-member that you have marked #3 was only used on manual transmission trucks, the sides of the manual trans bell housing mounted to that #3 x-member, if staying with the auto transmission setup just remove the #3 x-member. Mel
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
Old 01-08-2025, 11:59 AM   #4
AZBuckHunter
Thanks fellas, appreciate the help.
