Old 01-06-2025, 12:49 PM   #1
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
What's the extra hole in the cluster bezel?
It's on the right side under the wiper-washer.
desert-rat is offline   Reply With Quote
Old 01-06-2025, 01:08 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: What's the extra hole in the cluster bezel?
It’s for a manual throttle
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 01-06-2025, 02:10 PM   #3
desert-rat
Manual throttle? What's that?
Old 01-06-2025, 03:08 PM   #4
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: What's the extra hole in the cluster bezel?
It is a cable operated mechanism that attaches to the throttle linkage that raises and maintains engine speed above idle.
My 1970 Blazer was ordered with it. My dad used it to raise the idle speed up enough to for the alternator to run the all of emergency lights at fire scenes.
The knob/mechanism on a 1970 is on the other side of the cluster, under the headlight switch. 1971/72 manual throttle was located under the wiper/washer switch.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 01-06-2025, 09:30 PM   #5
weq92f
weq92f's Avatar
I'm wondering if people used this as sort of a poor mans cruise control back in the day...could be a bit dangerous I suppose though.
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 01-07-2025, 01:07 PM   #6
70STOVEBOLT
70STOVEBOLT's Avatar
Wasn't that hole used for manual choke on 67/68 models?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-07-2025, 01:49 PM   #7
1970cstblazer
1967-68 choke location:
Old 01-07-2025, 02:10 PM   #8
1970cstblazer
1968 with either 327 or 396:
Old 01-07-2025, 05:08 PM   #9
72c20customcamper
72c20customcamper's Avatar
-Kevin
In my experience the throttle will only open so much . Wouldn’t be able to maintain highway speed . In town maybe but you’d have to be pretty dense to try it . My golden has the manual throttle on it
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 01-07-2025, 07:40 PM   #10
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
You can pull the knob out to lock the RPM or twist it left or right to speed up or slow down. AKA Redneck Cruise Control. Only the brake pedal doesn't disconnect the cruise.
http://67-72chevytrucks.com/vboard/a...1&d=1736293030
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
Old 01-07-2025, 08:15 PM   #11
'68OrangeSunshine
'68OrangeSunshine's Avatar
Choke or Manual Throttle.
On 67/68s, the Wipers and Headlights are on the left, so it could be both.
As for the Red Neck Cruise Control -- there used to be a joke about a Middle Eastern Foreign Student [Pre Iranian Islamic Revolution, and way before 9/11/2001] who thought it was just like Autopilot in an airplane, and set it at highway speed to go back into the galley of his big camper and make himself a sandwich. He was surprized when the camper rolled. Most likely an urban legend, as they won't work that high an RPM, we're told.
Old 01-07-2025, 08:33 PM   #12
leddzepp
Moderator
leddzepp's Avatar
The bezel in the first pic is a 69-72.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 01-07-2025, 10:03 PM   #13
'68OrangeSunshine
I was aware of that but intended to be all-inclusive.
Old Yesterday, 12:41 AM   #14
Richard
I would think a main use of the manual throttle would be to control the engine RPM when a PTO is used. Think not so common to see a PTO on 67-72 truck. Maybe more common on the 40+ series trucks?
Richard
Old Yesterday, 05:07 AM   #15
58 Special
Junior Member
My manual chock was there to increase rpm while operating winch.
It doesn't work as a cruise way too slow. I tried it 35 years ago.
58 Special is offline   Reply With Quote
Old Yesterday, 04:28 PM   #16
don t. - 72gmc
I was told the throttle rod was to increase RPM to allow the alternator to recharge the battery when my truck had a camper, 5th wheel trailer.
The OP's post of this lever got me to look at pics of my dash. My lever is on the left side, under the head light knob....
Looking close at the 1st pic, it seems like the location of my throttle lever was done as a shade tree fix. Note the black plastic under the bezel.
100%...I dunno but still like my truck.
FWIW....I've never tried it, to see if the RPM's increase...Don.
don t. - 72gmc is offline   Reply With Quote
Old Yesterday, 04:46 PM   #17
Canuckvetter
That black plastic place card under the chrome nut is a factory item. They were also use under the manual choke on 68’s and possibly other years.
Old Yesterday, 06:12 PM   #18
leddzepp
Moderator
leddzepp's Avatar
The manual throttle was on the right side, lower hole in 67-68.
The manual throttle was on the left side, lower hole in 69-72 (all the ones I’ve seen anyway)
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old Yesterday, 07:17 PM   #19
1970cstblazer
'69-'70 was under the light switch, left side.
'71-'72 was under ther washer/wiper switch, right side.
Old Yesterday, 09:19 PM   #20
leddzepp
Moderator
leddzepp's Avatar
Thanks for the added info, now we know for sure for all years.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old Today, 02:30 AM   #21
58 Special
Junior Member
My 71 K15 suburban has its on the right side also. I added a switch on the left under the head light switch for a rear heater.
sure would be nice to have plastic tab that had rear heater printed on it.
Old Today, 08:36 AM   #22
'68OrangeSunshine
If you can't find one, it would be Period Correct to squeeze out a plastic label from a Dymo gun.
Old Today, 09:12 AM   #23
1970cstblazer
I've seen this on a Suburban before:
Old Today, 11:55 AM   #24
68Gold/white
Yes, they were common on school buses, of all brands.
68Gold/white is offline   Reply With Quote
